Hey yall....
Im thinking of selling my skyline because i cant afford the insurance :D I would keep it if i could ... So ive been looking around for a NA 4 cylinder... I was thinking about a Intergra type R .. they seem to be one of the most powerful NA 4's around.. does anyone know of any other powerful NA 4? also i have never taken one on, i rekon they wouldnt stand a chance against a skyline tho... has anoyone had the chance to race one..? :burnout:
  • Replies 67
Apparently if you drive a type R integra, you will love it. A friend of mine took one for a test drive, and says you wont realise how good it is till you experience it. He also says it feels faster than it actually is, and really puts you into the seat when accelerating. Handling also awesome, and if i had to drive an NA it would prob be something like that.
yea if u had to go for a type r, i'd say go for the civic. although it lacks the 200cc the integra has, the civic type r is actually faster due to its weight.
after that pop a B18 into it and you'd be smiling. wun be any competition for a turbo, but mighty powerful for an N.A.
Yes the integra type R's are very quick and agile cars,
I was looking at buying one before I bought my Skyline but it was just a lilttle to expensive at the time. Insurance will still be a bit pricey but not as bad as the Skyline being an import ect... :uh-huh:
I reakon a great driver in a type r will keep up with a good driver in a GTST.
At the bathurst hillclimb last year, stock type-r was 1 sec slower over 30 sec track, and I was on cheater tyres in the GTST (r spec tyres)
If you want a Type-R - BUY THE BEST!
dc2-98 is the best Honda possibly ever made. I've driven a standard one and it really is better than any FWD car I've ever driven (better than some RWD cars too).
The current one is not as good.
With 141kW it will keep up with all but the most sorted out, worked GTS-t Skylines out there.
It's not good for quarters though.
T.
Current Type R isn't as hardcore as the old one. I test drove one of the old ones and you really have to rev the motor to get the most from it or else there's not much at all.
I say get one if you want it as a track hack or be a weekend track racer.
I have an ITR and a GTR. I'm selling the ITR soon. Its a DC5. They handle really well. After upgrading to Eibach progressive springs, they are much, much better. Stock springs travel too much. Much better fuel economy as you'd expect. They do seem faster than they are. Handling is just fantastic and will keep up with or do better than most sports cars. Lacks power in the straights tho. In the end I was CRAVING for more straight line balls.
ITR insurance is much cheaper than GTR and because its sold domestically, you have a wider range of insurance providers. BTW I might have a JDM spec HKS super dragger catback exhaust for the DC5 ITR for sale. Brand new, unused. This model is not the same as the one sold in Australia. It was specifically imported.
I got the GTR because its much more of a hobby car; you can do so much more. Now I just need to learn to drive an effectively RWD car with about 400kgs more weight after ten years in FWD cars.
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
