If they didn't get a roadworthy done when you bought it, the car would not have had a legit safety cert, and therefore it was illegal to sell or advertise for sale.
Just to expand on that, a car can be sold without a safety certicicate but must be sold unregistered as-is. Obviously if they are trying to sort out that issue now, then they are very dodgy and sold it illegaly. Possibly try to get Qld Transport onto them, as they could be up for some big fines.
  • Replies 133
I spoke to qld transport they dont no how it was registered. then said it was registered and thats that
Dude get in there and start bustin heads. I agree with what has been said already. The absentee has either broken or wrecked it and they are trying to cover the fact.
My god this is very scary to hear....i guess doing the backgroud work before buying really helps....any hope you get it back...and its obviously the guy is not on holiday. he must have had a small altercation with the car....and try to fix up ASAP...
Can you Plz...PM me the place....Just wanted to know...so i can keep well away....and WORD of Mouth PEOPLE....make sure not another liner goes near !!!!..
You have just scared the hell out of me, I dropped my car off to the dealer today to fix some issues that should not have passed roadworthy. Luckily my dealer isn't in springwood, Looks like I will be keeping alot of contact with them to find out whats going on with my car.
please pm me the details I maybe able to help as I have a family member working for QLD transport. Other than that demand car by monday or money back as that is completly unacceptable.
If the car is a dodgey maybe thats just what they want her to do. :laugh:
sad to hear that amy.. humm whats the name of the yard or the addy if u could PM me that i shall keep a eye out for the car with those wheels and kit on as they might even change the plates + sticker .. sounds like they are playing with you .. i hope this gets sorted out for u
Firstlly;
That blows so bad, I have not seem something like this in a long time. I feel really bad for you and hope your venting on us helps.
Secondlly;
"Today Tonight" or "A Current Affair" will track it down for free...
I'd report it stolen anyway hey, go down there with the police report or whatever. That should fire them up a bit to get it back. Then work at ways to get the placed closed down or something until your car is recovered.
Not good tho. Deadset next car I buy its going to be new. And Im going to be down the docks when it rocks up.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
