Hey all, new here.
I am building a RB30 twin turbo engine for my R31, I am upgrading the oil pump, but im unsure what fits straight in and what doesn't
I am under the impression that the RB26 oil pump requires a collar to be added to the front of the RB30 crank?
any advice/thoughts appreciated.
https://www.sau.com.au/forums/topic/160982-what-oil-pumps-fir-a-rb30-crank/
Hey all, new here.
RB30E and RB30ET oil pumps also fit.
:blush: cheers :D
:blush: cheers :D
ORLY?????
who would have thought.
I would have used the RB30E pump, but everyone is saying that it'd be silly to do that, as the engine would probably run out of oil, the pump would have to support 2 turbos as well, so its upgrade time.
MAG86, i didn't think it was too bad, I was going to go with Suck_my_fat_wang, but it thought that was just a little over the top :wave:
the best usernames are allways the ones that cause a littel controversy!
I could have allways gone with Jihad_in_my_pants, Im sure you wouldn't have any probs with me slaggin of on a religion that isnt yours? (big assumption there, sorry if im way off)
anyways, thanks for the info fellas, much appreciated.
so how did you go with that on the RB30 crank, did it need the collar fitted?
I haven't fitted a collar yet, and im sorta thinking i wont need to, as the engine isn't being built for revs.
to my understanding, thats the main thing that kills them?
  • 4 weeks later...
Im running a 32 gtr pump on mine, havent had a problem, went straight on, way cheaper then the rb30et ones, and i wouldnt even bother with the standard rb30e pump, looks the same but flows different. I have been told that all rb series blocks share the same water and oil pumps, but someone might have to verify that..
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
