Been here a while thought I'd post up a pic of my r32
It's a GTS4, with an RB25DET, and some other mods :domokun: . Currently at the smash repairers, to have some rear end damage fixed (after being rear ended) Also Am having a GTR bar and grille put on. Had it for about 6 months, still getting used to it :P
https://www.sau.com.au/forums/topic/161213-my-4dr-r32/
  • Replies 88
Posted Images
  • 1 month later...
  • 4 months later...
Thx Don't "Plan" on doing much to it lol. Mod wise I've put on a high flow apart from that it had most of the mods done on itMaybe just get the gtr bar fixed, fit a catch can, some interior tidy up and leave it be. What does happen we'll see, could have something break of course.
https://www.sau.com.au/forums/topic/161213-my-4dr-r32/#findComment-3461998
  • 3 weeks later...
  • 7 months later...
Thx, ripped it up a bit understeering off a skidpan, havent gotten round to trying to fix it, found it a bit more trouble than it was worth, considering the amount of times it scraped, may get around to fixing it eventually.
https://www.sau.com.au/forums/topic/161213-my-4dr-r32/#findComment-3984745
  • 4 weeks later...
