Hi Guys,
Just wondering, it seems that when my car is idling it has a really faint miss every couple of seconds or so, nothing major and it drives fine under load and makes good power, just wondering if this is normal? It's hard to describe but its kind of like instead of having a constant purrr for the idle every 2-3 secs theres a slight quiet and then it starts purring again.
anythign to be worried about? Car is an R32 GTR.
https://www.sau.com.au/forums/topic/161260-slight-miss-on-idle/
I guess its fairly normal. Try new plugs first see if it helps. If not then get your injectors cleaned see if that works. I've just got my injectors done and its a fair bit better. Yet to see if there are any improvements in fuel economy yet tho.
Mine has done it ever since moving away from the heat range 5 1.1mm gapped plugs.
If I open the gap up the idle smooths out.
The miss is stuff all but I guess it can be an annoyance if you expect it to be baby smooth. No such thing with a modified car. :)
The miss is stuff all but I guess it can be an annoyance if you expect it to be baby smooth. No such thing with a modified car. >_<
I found the exact same thing going from 1.1 to .8 gapped plugs.
iv got his problem aswell and iv changed my plugs and put new spitfire ones on and no change
This can also be caused by resistor pack and wiring to the resistor pack.
Or even earthing of the resistor pack.
Most get a lot of heat over the years and need some attention.
You will know there is a problem when you operate the air-con.(at idle) and it misses regularly.
  • 1 year later...
Have we figured this out? I just changed from 5 plugs gapped to 1.0mm to 6 plugs gapped at 0.8mm and now I have this half miss stumbling sound coming from the exhaust every few seconds. Any updates?
Edited by cpt_impossible
Maybe get new coilpacks and clean the injectors like what others have said above?
I've noticed that this has started happening to my car as well. It's got splitfire coils and a change of the plugs about 3 weeks back and no change. A clean of the injectors might help, but too much a hassle. Everything is running good except for the idle so it doesn't bother me.
Yeah it happens when your spark plugs are gapped too close: from wiki
The gap adjustment can be fairly critical, and if it is maladjusted the engine may run badly, or not at all. A narrow gap may give too small and weak a spark to effectively ignite the fuel-air mixture, while a gap that is too wide might prevent a spark from firing at all. Either way, a spark which only intermittently fails to ignite the fuel-air mixture may not be noticeable directly, but will show up as a reduction in the engine's power and fuel efficiency. The main issues with spark plug gaps are:
· narrow-gap risk: spark might be too weak/small to ignite fuel;
· narrow-gap benefit: plug always fires on each cycle;
· wide-gap risk: plug might not fire, or miss at high speeds;
· wide-gap benefit: spark is strong for a clean burn.
A properly gapped plug will be wide enough to burn hot, but not so wide that it skips or misses at high speeds, causing that cylinder to drag, or the engine to begin to rattle.
I have mine gapped at 0.6 because my coilpacks are shit and i need new ones, but it fixes my hi-rpm misses, so until i save up for some splitfires i hav to put up with the missing at idle,
So yeah check the gap on your spark plugs, ideally should be 0.8
I have the same idle-popping issue.
Regarding plugs, I've read that the amount of resistance with power getting to the plug can change the ideal gap for your engine. So I guess a lengthy trial-and-error testing period is going to be the best way to get things the way you like them.
Edited by Legumis
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
