i know how to get the cover off and everything, then there are coil packs on top of each spark plug ? what do i do to get these off? I think you should replace them with like iridiums or NGK spark plugs, factory gap is 1.1mm but lots of line owners seem to regap to .8mm, at what rev range is it misfiring?
u disconnect the battery and press the brake pedal for a few minutes to make it totally powerless, if uve got an alarm system u will have to turn it off or just let it go off from the back up battery like i did. If u really want to drain the power leave the car for a whole day disconnected (sourced from http://www.powerlink.co.nz/~graeme/faq/). Reconnect and then start, the ecu will do a diagnostics and advance timing till it has a knock then it will retard so its perfect. I did it on mine but i didnt do it properly cos my alarm was goin crazy so i just reconnected and wil do later
im trying to work out how to get them out of the block, i pulled the plastic cap off and found that each plug has its own coil pack, isnt that cool, but how do i get them off without breaking sumthing. There are charts which u can prolly get from supercheap or sum mechanical place which shows damaged sparkplugs compared to a good one, and gapping them u should get a feeler gauge ($10) and just tap them gently till the gap is at .8 which is what ppl seem to like. the feeler gauge is to measure the gap, do not use a hammer or pliers, and iridium plugs shouldnt be regapped too apparently
OK i did mine 2 weeks ago so I know the process......
-Once you have removed the NISSAN cover, undo the electrical plugs (one for each spark plug)
-Take off the plug (just pulls off)
-The you will be looking at the top of the spark plug.
-In your socket set you will have a really big socket (i forget the size) and use the extension arm, put this socket over the spark plug and undo.
- Be careful not to drop anything into the whole (do 1 plug at a time to avoid dropiing anything down there)
- Get the new spark plug, screw it in (VERY TIGHT)
- Put the plug back on
- Continue.
:D:D hope that helps :)
http://homepages.kcbbs.gen.nz/benk/gtst/Fi...ndplugmaint.htm
I did my spark plugs last week for my r33 gts25t
i just followed the instructions of the web page above.
BTW don't tighten the spark plugs too much and not to leave them too loose. read up about it on www.ngk.com.au they tell you everything about them.
But for the R33 spark plugs NGK (BKR6E11) just normal copper ones B = Thread length 14mm for this length the tightness of the spark plug recommended by Ngk was HAND tight then with the socket wrench another 180degrees of a circle..
Changing the spark plugs helped me solve the miss firing problem which occured for me at above 4000rpm but my spark plugs needed replacement coz they done like 15000km for copper that it
being
-Take off the plug (just pulls off)-The you will be looking at the top of the spark plug.
What about the 12mm headed bolts that hold the coilpack framework down on the sparkplug?
Use the right spark plug socket!
NOT very tight at all, NGK recommend about 25 ft/lb torque when the head is cold (and that's not a lot of torque)
- Continue.
While you have it all apart, clean off the rubber boots on the coilpacks, make sure there's no carbon or moisture or stuff hanging around, as that can provide an easy path to earth for the spark pulse.
hey i reset the ECU.. AND Oh yeh!!!, NOT ONE missfire!! I went to 7100rpms in first and second.. Sounds great without that annoying noise. Also it handles a bit different too.. Better actually.
If it starts to missfire again in sayyy a 2 months, is it safe to reset the ECU again?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
