OK this will be of a work in progress as i dont have much spare time ATM
I will start by loading up all the important features with screen shots as this will show how it works and the options involved ie scales etc
I have added the wiring mod needed when using the plug and play GTR loom on R33 GTS-T
NOTE: GTT needs ignition adapter (internal plug in) and jumper 8 set to 12v not 5v as they have internal ignitors. In fact it is best to ALWAYS set this jumper to 12v (on all cars) as even if the ignition system is 5V it will not harm the system or any components.. it will only harm things if you set it to 5V and it is actually 12V.
**** ADDED ALL THE INSTALL NOTES AND HARNESS ADAPTERS****
Edited by URAS
  • Replies 765
How to remove AFM;
This is a simple operation that requires the optional greddy pressure sensor to be plugged into either of the inputs on the front of the emanage (yellow plugs).
  1. open data sampler map (far right toolbar icon)
  2. turn data sampler ON (click on/off icon)
  3. select airflow voltage and log its voltages (you will need to select greddy pressure sensor in the IGN and INJ too )
  4. drive vehicle and populate as much of the sample screen as possible (safest to do on dyno or track) but road is fine if you have enough demerit points :)
  5. cut and past this populated data into the AIRFLOW OUTPUT map.
  6. done
Here is a link to a easy to follow video (please remmeber it is an EVO IX so it uses HZ not voltge)
http://www.skylinesaustralia.com/forums/in...t&id=124155
Edited by URAS
SETUP STEPS;
  1. select car
  2. select maps you wish to adjust
  3. you can then select your preferred units ie bar or psi etc
Edited by URAS
EMANAGE ULTIMATE EXAMPLE: this is the current setup we run on our Drift car
www.skylinesaustralia.com/forums/index.php?showtopic=93880&st=80&start=80"
INTERNALLY STD RB26 (NEVER OPENED KINDER SUPRISE FRONT CUT)
EMANAGE ULTIMATE PLUG AND PLAY WITH OPTIONAL PRESSURE SENSOR RUNNING NO AFM'S
700CC BLITZ INJECTORS
BLITZ IDIII boost controller
TRUST T517Z'S TURBO'S WITH 8CM HOUSINGS (BABY'S)
TRUST INTAKE AND COOLER PIPING KIT
115MM TRUST R-SPL COOLER
GIZZMO PHENOLIC INTAKE GASKETS
HKS METAL THROTTLE BODY GASKETS
JJR ALLOY PIPE KIT
STD DUMPS
TRUST MILD STEEL FRONT PIPES
TRUST PETIR 80MM TITANIUM CAT-OUT EXHAUST
312rwkw @ 16psi OR 1.2bar
Response was the major requirement and it has delivered decent power too at a nice low boost level.
Edited by URAS
DATALOGING;
Below is a simple datalog, by scolling through the datalog a red square also tracks in the relevant map point. this makes finding detonating or fueling uses super easy and fast.
Edited by URAS
in the meantime if anyone has any question regards specific screen shots feel free to quiz me, i aint no guru but i am as confident with the product as i am with FC datalogit.
Is a two-step launch control ignition cut avail.?
Great to see, about time someone plugged the GReddy unit as it's definately a capable package.
Looks like you may be the only person I'll trust near my future boosted 350Z, this appears to be my only option for tuning.
http://www.skylinesaustralia.com/forums/in...st&id=88991
here is the control panel for the launch control :)
Just wondering if the ultimate unit is a much better option than the regular e-manage blue. I've just got a 33 with bolt on mods and looking for engine management mainly, want to sort out my ignition timing and so on as my curve is all over the place.
i have an emenage blue in Cats daily S13, 850cc injectors, T518Z, cooler and exhaust. It works fine but with the 850cc injectors gets a bit borderline and i will upgrad it to the ultimate very soon.
i supose it come down to how far you want to go mod wise, if your not doing much more than you have now then go right ahead the blue willl be a great upgrade (plug and play box set is avail for R33) but if your planning on more mods down the track definately go the ultimate or PFC.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
