OK this will be of a work in progress as i dont have much spare time ATM
I will start by loading up all the important features with screen shots as this will show how it works and the options involved ie scales etc
I have added the wiring mod needed when using the plug and play GTR loom on R33 GTS-T
NOTE: GTT needs ignition adapter (internal plug in) and jumper 8 set to 12v not 5v as they have internal ignitors. In fact it is best to ALWAYS set this jumper to 12v (on all cars) as even if the ignition system is 5V it will not harm the system or any components.. it will only harm things if you set it to 5V and it is actually 12V.
**** ADDED ALL THE INSTALL NOTES AND HARNESS ADAPTERS****
Edited by URAS
  • Replies 765
How to remove AFM;
This is a simple operation that requires the optional greddy pressure sensor to be plugged into either of the inputs on the front of the emanage (yellow plugs).
  1. open data sampler map (far right toolbar icon)
  2. turn data sampler ON (click on/off icon)
  3. select airflow voltage and log its voltages (you will need to select greddy pressure sensor in the IGN and INJ too )
  4. drive vehicle and populate as much of the sample screen as possible (safest to do on dyno or track) but road is fine if you have enough demerit points :)
  5. cut and past this populated data into the AIRFLOW OUTPUT map.
  6. done
Here is a link to a easy to follow video (please remmeber it is an EVO IX so it uses HZ not voltge)
http://www.skylinesaustralia.com/forums/in...t&id=124155
Edited by URAS
SETUP STEPS;
  1. select car
  2. select maps you wish to adjust
  3. you can then select your preferred units ie bar or psi etc
Edited by URAS
EMANAGE ULTIMATE EXAMPLE: this is the current setup we run on our Drift car
www.skylinesaustralia.com/forums/index.php?showtopic=93880&st=80&start=80"
INTERNALLY STD RB26 (NEVER OPENED KINDER SUPRISE FRONT CUT)
EMANAGE ULTIMATE PLUG AND PLAY WITH OPTIONAL PRESSURE SENSOR RUNNING NO AFM'S
700CC BLITZ INJECTORS
BLITZ IDIII boost controller
TRUST T517Z'S TURBO'S WITH 8CM HOUSINGS (BABY'S)
TRUST INTAKE AND COOLER PIPING KIT
115MM TRUST R-SPL COOLER
GIZZMO PHENOLIC INTAKE GASKETS
HKS METAL THROTTLE BODY GASKETS
JJR ALLOY PIPE KIT
STD DUMPS
TRUST MILD STEEL FRONT PIPES
TRUST PETIR 80MM TITANIUM CAT-OUT EXHAUST
312rwkw @ 16psi OR 1.2bar
Response was the major requirement and it has delivered decent power too at a nice low boost level.
Edited by URAS
DATALOGING;
Below is a simple datalog, by scolling through the datalog a red square also tracks in the relevant map point. this makes finding detonating or fueling uses super easy and fast.
Edited by URAS
in the meantime if anyone has any question regards specific screen shots feel free to quiz me, i aint no guru but i am as confident with the product as i am with FC datalogit.
Is a two-step launch control ignition cut avail.?
Great to see, about time someone plugged the GReddy unit as it's definately a capable package.
Looks like you may be the only person I'll trust near my future boosted 350Z, this appears to be my only option for tuning.
http://www.skylinesaustralia.com/forums/in...st&id=88991
here is the control panel for the launch control :)
Just wondering if the ultimate unit is a much better option than the regular e-manage blue. I've just got a 33 with bolt on mods and looking for engine management mainly, want to sort out my ignition timing and so on as my curve is all over the place.
i have an emenage blue in Cats daily S13, 850cc injectors, T518Z, cooler and exhaust. It works fine but with the 850cc injectors gets a bit borderline and i will upgrad it to the ultimate very soon.
i supose it come down to how far you want to go mod wise, if your not doing much more than you have now then go right ahead the blue willl be a great upgrade (plug and play box set is avail for R33) but if your planning on more mods down the track definately go the ultimate or PFC.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
