Hey guys,
I am keen to get a new ecu for my r34 GT-T Skyline, I was thinking of getting a Haltech Platnium Sport 1000, but I have also been looking at the cheaper option of Nistune and maybe a piggyback ecu. My maximum power figure that I would be aiming for would be 300kw eventualy. I have done a fair bit of work with standalone ecu's before, so I am tending that way. I am just looking for something that may be simpler and cheaper but will still do what i need it too, the Greddy Emanage seems to be a good option.
Thanks Joel
Nistune
  • Replies 765
Trent sent u a pm a lil while ago regarding emu/vman.
Do you have much expirence with vmanage..?
yeah, kinda pointless on alot of cars, the evos get good gains though.
Trent - by any chance has you tried E85 on a 1jz with the EMU? looking at doing it on my soarer cause we get 2 E85 servos here in the ACT this month and I have the Emanage lying around.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :thumbsup:
yeah its fine but you MUST wire up the coolant temp sensor as its needs lots on temp comp for cold start.
Thanks, was going to use the plug in loom to save hacking up the factory loom.
Im guessing it needs a bucket load more fuel when cold over factory.
yup.
Reckon factory 2jz 440's will be enough for the standard turbo's there is a set going cheap I can get my hands on.
Thinking I really should get some big ones straight up to make sure I have enought fuel for the future.
While Im thinking of it, would rb25 injectors fit the 1jz fuel rail, the plugs are different but thats an easy fix, asking cause I have set of high flowed 25det squirters sitting in the garage.
440's will be fine on petrol, they will see more power than your stock turbos can muster up. no chance on e85 though
and how cheap is cheap? they can be had regularly for $150...
aboot $100 bucks, I was more thinking just for the mean time, but the effort involved in swapping them over and then havng to go it all over again when I up the boost means I doubt Ill grab them.
just worked it out, the 2jz 440's are only 19% larger so no go for e85 even now, need 550s minimum :P
oh well.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :(
Wolf do a plug in for an auto soarer.
they do auto trans models.
are they preset will all the correct shift pressures and what not? if not the are no different to all other ecus.... all ecu's can run an auto if you know the solenoid switching and relevant input /outputs.
If it does thats pretty sweet, but i still wont touch them :D
They've done a fair few soarer auto's and most people are happy with how it comes pre-set. I like to take customers for a drive and customise the shifts to there driving style.
at what cost though, It wouldnt be free, and CBF spending 2K on a ECU plus 1500 to tune, then have to f**k around if the auto flares badly or shifts to early etc etc and at the cost per hour for workshop rates isnt cheap.
Cause there is no way you can program and auto box in a hour of cruising round the back streets.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
