Hey guys,
I am keen to get a new ecu for my r34 GT-T Skyline, I was thinking of getting a Haltech Platnium Sport 1000, but I have also been looking at the cheaper option of Nistune and maybe a piggyback ecu. My maximum power figure that I would be aiming for would be 300kw eventualy. I have done a fair bit of work with standalone ecu's before, so I am tending that way. I am just looking for something that may be simpler and cheaper but will still do what i need it too, the Greddy Emanage seems to be a good option.
Thanks Joel
Nistune
  • Replies 765
Trent sent u a pm a lil while ago regarding emu/vman.
Do you have much expirence with vmanage..?
yeah, kinda pointless on alot of cars, the evos get good gains though.
Trent - by any chance has you tried E85 on a 1jz with the EMU? looking at doing it on my soarer cause we get 2 E85 servos here in the ACT this month and I have the Emanage lying around.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :thumbsup:
yeah its fine but you MUST wire up the coolant temp sensor as its needs lots on temp comp for cold start.
Thanks, was going to use the plug in loom to save hacking up the factory loom.
Im guessing it needs a bucket load more fuel when cold over factory.
yup.
Reckon factory 2jz 440's will be enough for the standard turbo's there is a set going cheap I can get my hands on.
Thinking I really should get some big ones straight up to make sure I have enought fuel for the future.
While Im thinking of it, would rb25 injectors fit the 1jz fuel rail, the plugs are different but thats an easy fix, asking cause I have set of high flowed 25det squirters sitting in the garage.
440's will be fine on petrol, they will see more power than your stock turbos can muster up. no chance on e85 though
and how cheap is cheap? they can be had regularly for $150...
aboot $100 bucks, I was more thinking just for the mean time, but the effort involved in swapping them over and then havng to go it all over again when I up the boost means I doubt Ill grab them.
just worked it out, the 2jz 440's are only 19% larger so no go for e85 even now, need 550s minimum :P
oh well.
I still want to be able to run 98 so trying to figure out the best compromise of injectors that are big enough for upto the 300rwkw mark on E85 yet still be able to control the injectors with the EMU, The car is Auto so no chance of being able to use a real ECU :(
Wolf do a plug in for an auto soarer.
they do auto trans models.
are they preset will all the correct shift pressures and what not? if not the are no different to all other ecus.... all ecu's can run an auto if you know the solenoid switching and relevant input /outputs.
If it does thats pretty sweet, but i still wont touch them :D
They've done a fair few soarer auto's and most people are happy with how it comes pre-set. I like to take customers for a drive and customise the shifts to there driving style.
at what cost though, It wouldnt be free, and CBF spending 2K on a ECU plus 1500 to tune, then have to f**k around if the auto flares badly or shifts to early etc etc and at the cost per hour for workshop rates isnt cheap.
Cause there is no way you can program and auto box in a hour of cruising round the back streets.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
