  • Replies 765
You asked a question so I answered it. I shouldn't have bothered. I have an EMU in my own patrol so it's not like I'm against them. You made a statement that you can't buy a plug in ecu for an auto soarer, I was just correcting you. I won't make that mistake again.
Edited by O2 Autosports
For any one else, (not zebra, I know you don't want one) wolf do a plug in for an auto jzz30 1jz gte soarer.
p.s. when you stop making in correct statements, I'll stop posting.
hi all i am back on land of the skyline but now with r34 gtt auto i recently put on the following
e manage ultimate with ignition adaptor and set to 12v
with complete universal loom
specs are
nismo fuel pump
blitz 540cc injectors lag set to 1.02 and .60 for stock
and new roller bearing turbo unit with steel turbine
the problem i am having sometimes you can struggle to start
1 .when it start it idles fine etc but it has slight misfire once evry few seconds but revs very clean
2 . one you drive it after few minutes tcs and slip light will come on and stay on and canot switch it back on and sometimes it will stall
also how do i remove fuel cut
any help would be greatly apreciated
thanks
specs are
nismo fuel pump
thanks
has enyone used a z32 maf on auto box model r34 gtt
as i am having issues with it z32 maf is wired correctly setting change on e manage . but when it get to 3500-4000 rpm it just holds backs . but when use stock maff its ok , it feels like car does not know when to change gear etc
Trent/anyone
how do you set this c*nt up so that it switches between maps when the external switch is changed. now map 2 (for both ign and inj.) just makes the correction on top of map 1. i dont mind it doing it with fuel but need to have two different timing maps selected via the switch.
the f*ck do i do?
cheers,
Ben
Mine is setup for 98 and adds the fuel and timing for e85 with the secondary maps. Cant you just add or subtract the timing you need from the primary one? Or just dump the new map on with the laptop...
Once you go E85 you wont want to switch back anyway. :)
Once you go E85 you wont want to switch back anyway. :verymad:
its lpg, i just cant remember your map setup atm ben so i will check in the morn
yeah scotty, dual fuel. trying to set it up so that fuel 1 is as it is now, fuel 2 will have main load input as 3 bar map sensor, only to add fuel up top. so it iwll be working over the top of the primary fuel map. then going to run both ignition maps off 3 bar, but wiring in a relay to the 'external switch' on the emanage, using a signal from the lpg lockoff to swap timing maps between lpg and 98 when the fuel system swaps over.
simple in theory but i'm a nugget of a tuner lol
thanks heaps trent. worst case i'll just wire it all up and deal with it when we bring it down next :P ps: we both changed out minds, i decided keeping the td06 was a better idea, and tony caught onto liking the gt35r, so car now has a gt35r on it lol
Edited by VB-
It still amazes me how well the Ultimate lends itself to any type of install with all manner of wiring and setup.
Spoke to Trent today, he mentioned the fueling issue. Any other way around it? What about a secondary petrol injector for the top end? Real dual fuel... :P
sort of is and sort of isnt another way around it... gas system now takes an injector signal and uses that. there is a mechanical adjustment to get the gas injectors flowing the same as the petrol ones (just a restrictor on the injector itself). in reality we need a more powerful computer so we can remove the restrictors and run the gas injectors to full flow (which is a shitload more than anything else on the car will flow).
could wire them direct to emanage but there is no point as the emanage cant run two different size sets of injectors, so the gas is being held back to the same point the petrol is. mate wants to keep dual fuel, so ditching the petrol system and just running lpg isnt an option.
another option is upgrading petrol injectors to 800's and changing the restrictor on the lpg injectors to also make them '800cc', same as the petrol injectors. he has a set available to him cheap, but then there is no point doing all that JUST to push the gas further, if he was to do it, he'd wanna push the pterol tune further too, but if we went this route, with 800cc injectors, i've already told him we'd be going e85 :P but we'll need another fuel pump, better clutch etc. + his catback will probly start to become a restriction at this point, and it all gets out of control real quick.
dual fuel, E85+lpg is on the cards for the future though :D
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
