Are you interested in a custom modified PFC to suit your RB20 and RB25?
336 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
As we all know Apexi have ended production of the RB20/RB25 PowerFC.
For whatever reasons, we don't care. There have been a few rumours surfacing around that the RB26 PFC will work on both the RB20 and RB25.
I expect that it *will* work but some changes are required to be made to make it work and be user friendly.
There are some known "gotchas" for either version and some unknown / risks as well.
Known changes:
- Injector wire changes
- Injector setting changes
- Airflow wire changes
- Airflow setting changes
- Stock map changes
- 02 sensor setting changes
Known "gotchas":
- RB25 version will NOT have working VCT support - The RB25 engine by default has variable cam timing. This is turned on at 1800rpm and off at 4700rpm.
Customers who have aftermarket exhauts cam gear are not affected by this known "gotcha'" as fitting aftermarket cam gear negates the VCT.
Jaycar have a product to build your own "rpm" on/off relay system but its completely manually and you would have to do it yourself.
- RB20 versions will face an issue with standard injectors and the correction involved. This is because we are limited to how much correction we can throw in.
We are fairly certain it will be OK and work acceptably, you will have to dial in more fuel in the INJ map than normal to make it work. I will provide stock maps to suit this.
- 02 feedback might not work. This is because the GTR PFC and stock ecu have no support for 02 heater control but GTST needs it
Bonus Features:
- Working airtemp support
The mainstream RB20 and RB25 powerfcs do not support airtemp. That is they do not have the AIRT sensor and do not use it.
The RB26 powefc does and you can simply purchase / find an airtemp and connect it up and it will work. This will provide air temp correction on the maps and show it on the hand controller
- Twin AFM Support
The "modified" version will support single or twin AFM depending on your power needs. So you can run say for example twin z32's or twin rb25s MAFS on your single turbo RB20 or RB25
- Twin 02 Support
The "modified" version will support single or twin 02 depending on your power needs. So you can run say for example twin 02 sensors if you have a twin turbo setup.
- Djetro Option
The mainsteam RB20 and RB25 only let you choose LJetro, that is the AFM only version.
The RB26 PFC lets you choose either lJetro (afms) or Djetro (maps) and either will work.
I am unsure at this stage if it would work and how feasible it is (ie: Djetro Rb20) as you would need twin MAP sensors in a suitable location.
How:
I will obtain a stock Rb26 PFC and then with a suitable wiring loom adapter make the required changes.
I will use software to edit the stock RB26 settings to suit which ever engine combination you need (RB20 or RB25)
The loom that I had in mind
The wiring loom adapter or pass through lets me make changes to suit your engine and not hack your existing car loom.
This makes the 26 PFC still a 26 PFC and your car still a stock 25 or 20 engine / loom setup.
So you can sell the PFC as a stock 26 PFC (just do a DATA INIT before you do) and sell your loom or change to a stock Rb20 / Rb25 ecu.
The changes on the loom control include injector, afm and 02 sensor changes need and there is no secret "firmware" changes etc to it.
It simply makes it easy for me to do my changes and for you as a customer to go back to stock and negates the need for you to hack your own loom.
The PFC kit and loom (that I supply) will be a direct plug and play to your car. Plug in the loom to your current loom and then plug the loom into the PFC.
Thats it, Away you go, run the self idle learn procedure and you are done.
If you want to go back to the stock ECU or another ECU, remove the loom and plug it into the factory car loom. (no mess, no fuss)
Why:
I am trying this because there is an obvious lack of PowerFC's for the RB20 and RB25.
People have been resorting to buying them off ebay and other places for mega prices $1500+
I feel that it should be cost effective and relativity easy for the user to get a PFC hence the work I am doing.
I have my own full time job and this is not an ebay scam / make money deal.
I am simply offering a service to modify 26 PFC's to suit RB20 and RB25.
!! WARNING !!
I will NOT provide a warranty, the ecu you receive off me is provided on a do so at your own risk.
If it fries your coilpacks, melts your CAS, cooks your ultra super cool cam gear, melts pistons etc I cannot be held responsible.
This is a completely UNSUPPORTED HACK and violates any warrannty / guarantee. Of course I will test each unit but there are always risks.
I have been assured that other than the changes mentioned above are fairly normaml and that its a direct swap.
!! What do AP Engineering do !!
AP Engineering for some time provide hacks on mainstream PFCs to suit other models.
The RB20 AP engineering unit is simply an RB25 ECU with removed VCT support and the minor map changes.
They even open the ECU ecu and cut tracks and make wiring loom solder changes to achieve the goal.
Whats next
This is a work in progress. It was originally setup as a done project but it hasnt been completed and didnt work out.
Someone else will need to take on the legacy here.
  • Like 2
  • Thanks 1
https://www.sau.com.au/forums/topic/161511-rb26-pfc-working-on-rb20rb25/
i would be keen pending price and that
so tuning wouldnt be a fuss? also do you "have" to run duel afm for it to work?
tuning wouldnt be an issue as its a normal PowerFC.
You don't have to run twin AFMs, the changes I make will make it use only 1 AFM and retain the stock RB20/RB25 wiring and AFM
The price I have come up with is around $1250 for the unit.
This would include all the changes needed and the standard box, jap manual etc etc and shipping to your address via normal aust post.
The wiring loom alone costs about $200 and I have to allow for fluctuating aussie dollar / jap yen for the standard PowerFC unit.
The legacy AP Engineering units are $1499 with hand controller so I think my price is reasonable.
The PowerFCs will be new from nengun. Hopefully, I can just work on makes changes to the wiring loom only and the stock FC is simply a 26 FC.
This would mean you would have to order the FC from nengun and the warranty would lie with yourself & nengun. I would supply the loom to suit and instructions on how to set it up to suit the RB20 or RB25. This would avoid me buying dozen's of 26 FC's and your normal warranty would be with the supplier directly. Otherwise I have to act as a proxy for the warranty on the FC
I have spoken with my supplier and they will let me do the wiring loom changes for me so this makes it even easier than we thought.
I will simply setup the loom and required changes and then simply sell the loom to suit RB20 & RB25. It will be upto you to source your own RB26 PFC from either 2nd hand, new, nengun etc. I will provide some instructions on what to change on the hand controller before starting the car so it should be straight forward.
More to come when I find out total costs from the supplier, I am unsure how much they will charge me to setup the custom loom and make changes then batch build them.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
