Traction rods... is the name given to that third short straight arm in the rear of a s13/R32/Cefiro etc. Ive got adjustable traction rods, camber arms and toe arms in my drift R32 and i am looking at further increasing my rear grip when the power is down.
I have had a bit of a play with adjusting the traction rod, but i am not sure which way i should be adjusting it and how much by.
So far my rear alignment is like this.
0.5 Degrees Camber
1mm total toe in
traction rod is 4mm shorter then stock.
High speed grip is great... how ever at the slower speed corners it just doesnt want to put the power down, also there seems to be a lack of mid corner grip at the front also.
Was thinking of changing the traction rod length again and see what else i can get happening. I understand that it is suppose to control how much toe you have while under squat... But yeah... i'd like some more info on this!
https://www.sau.com.au/forums/topic/161613-traction-rods/
hmm yeah those specs i gave you work best for S13 (4mm) so there probaly is room for improvement with the ceffy. What coil-overs and rates are you using. i forget sorry.
and most importantly what make,size and model tyres.
Edited by URAS
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3003311
there was a good thread on ns.com about that rod a while ago - Trent URAS posted and a couple of other informative people replied too...
i think the final conclusion was not to change the length of it - if replacing with a adjustable one, set to standard length, this is just what i remember though so hopefully you can find the thread.
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3003974
i wish someone would. I have ikeya formula traction rods in my GTR. When I put them in I had NFI how to set them up. I can see they look to effect a small toe change too when adjusted.
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3011675
OOOH goody, a chance to get technical.
Let’s start off with what I do when fitting adjustable rear camber bushes, as most people know I don’t use aftermarket arms, but the principles are the same.
First thing is to stick the car on the wheel aligner and set the toe to where I want it. Let’s say 2 mm toe in each side.
Then I remove the upper control arms and the traction rods and fit the adjustable bushes. Put them back in the car and adjust the camber to where I want it. Let’s say 1.25 degrees negative.
Then I check the toe alignment, it should be 2 mm toe in each side. If it isn’t, I use the traction rods (not the tie rods) to correct the toe. Why? Because this means the car now has the same amount of bump steer that it had with the standard arms (and bushes) in it. Basically as Nissan designed it. Sometimes it is necessary to go back and readjust the camber, but it is usually just a fine tune, if anything at all.
If you haven’t followed the above process, then you most likely have stuffed the bump steer, and it is rear steering all over the place. Like it still had HICAS but worse for traction. So what do you do?
You need a bump steer gauge, although you can do it on the wheel aligner, if you go about it the right way. This is what I do;
First thing is to remove the rear wheels, then the spring and shock units from the car. Put the rear wheels back on and use axle stands to set it at the normal ride height.
Then check the alignment, using the above it should still be 2mm toe in. Now jack the rear suspension up 50 mm and check the toe settings, it should still be 2mm toe in. Then jack the rear suspension up another 50 mm and check the toe settings, it should still be 2mm toe in. Now drop it down 150 mm and check the toe, it should still be 2mm toe in. Another 50 mm down, same toe, 2 mm in.
Swap over and do the other side, same process, 4 measurements at 4 different heights. If the toe is always 2 mm in on both sides, then you have zero bump steer.
But if the toe changes as you go up and down, then you have to adjust the traction rods until you eliminate the bump steer. This can take a few goes on each side, as small adjustments are required.
The final step is to make that the camber is still the desired 1.25 degrees negative both sides.
If you want to have some fun, try going up another 50 mm (to 150 mm) in the suspension travel. Then watch the bump steer and camber go all to shit. That’s why it’s a stupid idea to lower Skylines much below 340 mm at the rear.
Good luck and happy measuring
::( cheers :(
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3012860
How do you adjust the Whiteline camber bushes while on the car? With the upper control arm I just use the standard camber pins, but I'm not too sure I can see a way to adjust the traction arm bush?
Remove the inner end bolt, pop the end of the arm up and twist the eccentric crush tube. It's a fiddle, but you only have to do it the first time you install them.
:happy: Cheers :happy:
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3015034
Ah, I thought it might be something like that. Now just have to set aside a couple of hours to use the wheel aligner...
If you opt for a different amount of toe on the rear, do you have to change it again?
Nope, same as the front.
Once you do the bump steer correction, it won't change unless you change the length or pick up points of the control arms.
Changing toe settings should have zero effect on bump steer.
:rofl: cheers ;)
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3015500
LOL...you guys :laugh:
Just do what i do and drive around whatever ill handling heap of sh1t Nissan it is you drive. Must cheaper :)
lol I thought I was the only one that did that....good to hear I am in good company Roy
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3016236
excellent info gary.
I'd be interested to see what you think about my current arrangement, I set the traction arms to 4mm shorter then stock, and my ride height is about 320/320mm all round, I do know that it should be higher however the HSD"s in my car wont go any higher then that. So since the car is already lowered a fair way, and under drift conditions the rear see's a fair bit more squat, i was trying to gain as much traction i can.
Alignment as 1mm toe in, 1 degree camber and 4mm shorter traction arm.
I have a feeling that after reading what you have read that i probably have gone too far and they need to be closer to standard arm lengths.
https://www.sau.com.au/forums/topic/161613-traction-rods/#findComment-3019788
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
