  • Replies 156
What happened to you and Stace and Twoogle, Paul?
the new engine is sitting in the back of our Jeep....not in the engine bay of the Skyline....due to components being held up at customs in a shipment we could not get the engine assembled in time. We finished assembly yesterday.
Massive thanks to Peter for his efforts in organising this event and MadManz too I think it was. It really is a big effort.
Thanks again to the same two guys for getting me home on a trailer so I didn't have to sell a child into slavery for a truck.
And just when you thought the day was over; the rain came just in time to put a halt to the bracket racing fun. WSID have agreed to that the 8 undefeated will gain free entry on a wednesday night street meet (which one to be advised) and a lane to themselves from which they will finish what was started today.
Should be fun.
I made only 4 passes but reeled in a best of 12.419 @ 110.53 before bowing out to the might of the Mickey Thompsons.
I ran 111 a couple of times and on one run where I thought I did well the end timer didn't work so no MPH or ET.
Basically I smashed the inner cv on pass number 5 I think it was. On the 4th pass I tried to launch at 5000 rpm but accidentally revved to about 5800 before the clutch bit. The thing just launched.
1.783 60'
That became my new pb as detailed above so I thought, well looks like these tyres can hold 6k so that's what they will get. Held it there then engaged clutch and released handbrake. Kind of went like this; f**kIN YEEEAAAA - BANG! I stopped on the track and looked in my drivers side rear view mirror only to see a couple of good sized ball bearings chasing me down the track. I got out and caught them as they went by (artistic licence used here) and waited for my tow back to the carpark.
Man it was fun. I can only assume that with some more practice and stronger cv joints I can get better 12's and maybe even a high 11.
Was heaps of fun... pity the rain came in after the 2nd round of bracket attack. Gave me a chance to actually win some races...LOL.. :P
I was the slowest car there... with a 14.5 @ 93mph. Yet i was able to beat 1 12s and 1 11s V8 ...YAY!!!
Unlucky to some of us.... Abo Bob, NXTIME, hanyou and silvergts-t on their problems and any others that i didnt see.
What happened to NXTIME and silver
What a great day!
I would like to say thank you to all participants. Your contribution to the day was outstanding.
WSID feedback was 100% on every aspect of the day. Seeing both camps pitch in & help each other was great.
We were a little bit concerned to see the number of skylines knocked out after the first round of bracket racing.
Round two put a quick stop to that, the skylines were knocking out the V8 guys everywhere.
The rain out was a bit of a bummer however.
But wait there is more...................
Due to our exemplary behavior WSID has agreed to let the 8 finalists fight it out free of charge with a private lane hire on a Wednesday night street meet.
That's right, they will let the finalists run an 8 car bracket event on a Wednesday night.
We will have our winners, so the day is not over yet.
There are still 6 trophies up for grabs.
Well done everybody, you are all welcome back to any V8owners event.
Adam, you have now driven an LS1, are you coming over to the dark side???????
Peter.
Well done to all that participated.
Unfortunatly, we didn't make it 2 meters from the trailer.
Our HG spat trans oil everywhere, and after a big attempt to fix it, we found a crack in the housing.
Took it home, pulled the engine and trans out to find a 10" crack all the way around and 2 large chunks missing....
Oh well, would have loved to run some skylines too!
Thats how it goes
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
