Currently have a few extra sets from the previous group buy, PM me if you want one (no waiting time! pay and receive them next day)
I am running a R33 Gear & Hand Brake Boots group buy. Some people missed out last time because the group buy was filled, however due to popular demand I have opened a new one for those who missed out.
I have sourced a manufacturer that makes genuine leather Gear & Hand Brake Boots for R33 Skylines.
Nissan sells them for $150. He sells one gear and hand brake boot for $95 with postage to Australia.
But if we make a minimum of 10 orders, for $55 you will get a gear stick boot, a hand brake boot and express postage to your door.
If you are interested please PM me or post here to be included in this group buy.
Current Groupbuy
Deano45 (payment received)
stevo~
dat16dog
FLY12N
jazz
levinet (gear boot only)
greggers
cafe
Please leave positive trader feedback when you receive your boots and I'll do the same :D
Edited by pablo101
  • Replies 518
Posted Images
Any chance these could be made in other colours or is it just black on offer?
Sorry, only black leather available
Does the hand brake boot come with the wire frame as well or does that need to be provided.?
Cheers.
Steel wire is already included in the hand brake boot, no modification needed on installation
can you only buy just gear cover?
dont need the handbrake one as thats in excellent condition..
Sorry, it comes as a package, I suggest you keep the other or pass it to a mate
Edited by pablo101
I'm still waiting on the supplier to send them to me.
The following I have recieved payment from:
GTshortie
igota33
85URK
scorp
operationsideways
SKYL9
aaron_25t
R33fourdoor
Still waiting payment from:
r33freely (no reply to my PM)
Endorean (no reply to my PM)
Edited by pablo101
Howdy Pablo,
Thanks for confirming that you've received our payments.
Have you had any indication as to when when the consignment is due to arrive? Hopefully won't be too long as I'm itching to fit them up! :D
I appreciate the effort you've gone to in setting up this group buy and look forward to your next update.
Cheers, Mike
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
