I have put a deposit on this r33 gts-t, what do you guys think of it?
R33 GTS-T, 1994 model, genuine car, Rare Factory Black, 5sp manual with Electric Sunroof, Grade 3.5 Auction with NO accident histrory. Straight vehicle with good modifications, incl coilover supension, Blitz Adjustable Boost Controller, updated rear spoiler, Apexi N1 exhaust, Apexi Super AFC and Air intake, factory sunroof, runs very well, incl full compliance.
https://www.sau.com.au/forums/topic/162172-r33-gts-t/
id say around 12/13k
looks clean though....and some nice mods to start u off.... :(
edit: thats a lot of wires hanging around the engine bay....should probalby try to get them cleaned up a bit.....(incase cops decide to have a look in there)
Edited by emsta2003
https://www.sau.com.au/forums/topic/162172-r33-gts-t/#findComment-3013449
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
