  • Replies 107
Ahhh...looked familiar :sorcerer:
What's happening on the induction side of things - is that a single throttle body manifold I spy?
Are we also going to MAP load sensors sir?
Hypertune Plenum and CNC'd runners and single Hypertune throttle body with 97mm butterfly.
No MAP sensors...new Z32 AFM's actually...it will work.
sooo would love to know what that set you back mate.
pm FTW!
here's a list...you work it out
BLOCK...sonic test, chemically clean, torque plate bore and hone, mill block, drill and tap for 12mm main studs
CRANK...new Nissan crankshaft, drill crankshaft to remove alloy oil plugs and tap for screw type
ENGINE...JUN pistons pins and rings, JUN conrods, JUN oil pump, JUN main studs, ARP head studs, Tomei cam cap studs, new Nissan oil squirters and bolts, TRUST "drag" head gasket, JUN metal inlet exhaust gasket kit, Nissan gasket set, Hi Octane 9 litre baffled sump.
HEAD...machine for cam lobe clearance, remove oil plugs thread and grub screw, full race port and polish, modify combustion chambers and high polish, instal bronze guides, cut 3 angle valve seats, lap valves and set heights, JUN camshafts, JUN titanium retainers, JUN valve springs, Tomei lifter buckets, Nitto stainless steel valves (1mm oversize), Mines cam cover baffle kit.
EXTRAS...full engine balance and assembly, fit front Cusco 1.5 way diff to new sump, port match all manifolds turbo's and plenum, TRUST twin entry "drag" intercooler, Hypertune race plenum, Hypertune 100mm single throttle body, NPC twin plate race clutch.
I already had the turbo's (HKS GT-RS) manifolds and dumps which have been ceramic coated from our last engine. These have only done two passes and are as good as new.
As you can see nothing has been left to chance.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
