  • Replies 73
i know they arent normally that cheap hence the reason why i bought it. im not sure if it was a special price but it was seriously approx 18 dollars. the others things i bought (a radiator cap, oil cap, filler cover) were around the 3500 - 5500 mark oh and the kill switch cigarette lighters were i think approx 1800 , so i bought 2 of them 1 yellow and 1 red oh and also nismo badges approx 1300 - 1400 from memory i bought 2 of those also oh and a nismo lettering sticker was 1000 exactly.
is that near tokyo big sight? if thats the one i dropped by shortly however i left quickly after i learned there were older skylines and other cars doing something which looked like 1/4 miles but werent(????) on the outside part of the big sight
