Yeap!! thats exactly what my car is now! :thumbsup: just a normal non alsd non abs skyline!! My mechanic is still going to look into the abs issue, but for now i just have to deal with those two pesky lights on the dash!
and yes.. my car gets driven everywhere without issues :D
Lol!! Yeah i know richie!! i'll eventually get a 1.5 way.. need to save up a lil bit first :P
and cerci!! Sure thing! It was ProConcept in Meadowbank.. Their details are in my sig :P
Also I spoke with Jeff from SSS Automotive (9896 6111) and organised the stock r33 diff and drivetrains to be delivered to Josh at Proconcept
very nice moanie. I think the reason your abs isn't working is that the half shafts on the new diff may have different ABS rings or none at all, if hes pulled the pump for the ALSD out then the wiring for the pickups will have gone too.
its not a big job to pull the cluster out and remove the ALSD and slip globes.
Edited by mattymagoo22
Mona,
any chance you can get some more info regarding the alsd resevoir and lines etc and what Josh did to remove them .. just so these others may have a chance to do the swap themselves if need be
yeah sure! will ask when i see him next week!
will also ask about this matty!!! I remember him saing something about borring a ring from a different diff? i find it hard to understand unless i'm seeing whats happening, so will also get this confirmed! :ninja:
and yeap! globes won't be a problem :nyaanyaa: its scarey seeing them lit up though! so not used to it!
the silver thing with teeth on it is the ABS ring (man i hope this link works).
that ring is on the half shaft, on the other side of the bolts is the rear driveshaft/ c/v axle
Hope this can explain some things.
http://i12.tinypic.com/48m5lwz.jpg
hope noone is mad i borrowed their picture
yeap that link works!! thanks :sick: i'll find out if the stock alsd uses different rings! i'm fairly sure from what josh was saying, it did, and he had to borrow the ring from elsewhere! but will reconfim all this when i'm there!
yeah nice . hoping that the pic and my info can add to your database of knowledge.
stil need to know exctly what you need for a swap.... diff, half shafts, tailshafts and flanges for the c/v's.......?
pm me or send your number and we could have a chat or whatever......
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
