Hi Guys,
The SAU will be supporting a Skyline Afternoon at the track day on MAY 17.
The afternoon will run as one of our standard events.
The cost will be $130 (plus a AASA license if you do not have one)
To book in please read the booking rules at the following link and secure your spot with a $30 deposit.
http://www.timeattack.com.au/bookings.php
If you are not a member of track day and want to come, please fill in the form at
http://www.timeattack.com.au/mailing.php
I will keep a list of all members who have booked in and paid the deposit on this first post:
AFTERNOON SESSION
SAU Skylines
1. DEP nate79
2. $0.00 gts25t4door
3. PAID Lazy-Bastard
4. PAID jlnewton
5. $0.00 SirSkyline
6. PAID Willo
7. PAID MountainRunner
8. PAID silverbulletR33
9. PAID FineLine
10. PAID jetman
11. $0.00 IanB
12. $0.00 J-Boy
13. $0.00 pear
14. $0.00 si
15. $0.00 Ad_N
16. $0.00 Keeper
Non SAU Skylines
1. Andrew C
2. Russell A
3. Darren M
4. Matthew G
5. Chris A
6. Peter A
7. Rajon D
https://www.sau.com.au/forums/topic/162597-track-day-may-17-sau-afternoon/
  • Replies 45
Hey Guys,
There are less than 10 spots left for the afternoon now. If you want to get in on the Skyline afternoon please book in NOW.
We will be running the Sprint and Clubman track in the afternoon.
I already have 5 Skylines booked in for the morning as well. Probably end up a huge Skyline day.
Paul
Hey Glenn, all the 'Non SAU Skylines' are all Skylines who are not SAU members, so you would be a 'Non Skyline SAU Member' lol.
IanB, I will hold a spot for you.
lol... kinda figure that out only after making the post :thumbsup:
how about a 'Ex Skyline Ex SAU Member' category... i can run the track all by myself :)
Hi Guys,
AFTERNOON SESSION
SAU Skylines
1. $0.00 nate79
3. $0.00 Lazy-Bastard
4. $0.00 jlnewton
5. $0.00 SirSkyline
6. PAID Willo
9. $0.00 FineLine
10. PAID jetman
11. $0.00 IanB
12. $0.00 J-Boy
Non SAU Skylines
1. Andrew C
2. Russell A
3. Darren M
4. Matthew G
5. Chris A
6. Peter A
7. Rajon D
Hi All,
I need everyone who is definately coming to the track day to make payment (or deposit) ASAP. (less than 1 month away now).
I now have more people than spots, so I will have to start releasing any unpaid spots.
If you cannot make it and are on the list, please let me know.
Thanks
Paul
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
