  • Replies 45
Hey Guys, anyone who has not paid yet, please do so and shoot me an email or PM asap. I have a waiting list and will have to release any unpaid spots over the weekend.
I will also update the list in the first post over the weekend, once I know who is definately locked in.
Looking forward to seeing such a crowd of Skylines lining the pits and cutting times on the circuit !!
Paul
Hi all, I'm wondering if anyone would like to share in on an afternoon spot for May 17? I actually have a spot for the afternoon SAU session on May 17 @ QR but i'm probably only going out fer a couple of sessions to do some testing on the car, therefore i wouldn't fully utilise the full track time that i would be given. If someone is interested in sharing in, you would have at least half the number of sessions or more, no less, to run yer car on the track in the afternoon. I have done this before with paul's approval at a previous trackday, so its no problem at all. The cost for the whole afternoon session is 130, so in this case it would be 65 each, and like i said, i guarantee you will have at least half or more, no less, of the total number of runs in the session. If anyone is interested, please tell me ASAP so that i can confirm this with Paul.
Cheers~
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
