I'm looking at buying a house so i need get a a more tame car :) for a while
This GTR won the SAU best R33 GTR award 2 years ago...
It currently has about 84,000km and about 20k on the engine...
It currently makes about 300kw atw on 18psi this car has virtually no lag its very very responsive...
I use it as a daily driver but its built to be a track weapon.
The car has been serviced by UAS...
CP Forged Pistons (20 thou oversized)
Carrillo Forged Conrods
SPS CARR Conrod Bolts
Tomei Cam Sprockets
Tomei 1.2mm Head Gasket
Tomei Gasket Kit
Tomei Oil Gallery Restrictor
ARP Head Studs
Sard 660cc Injectors
Bosch 044 Fuel Pump
NISMO Fuel Regulator
Z32 Air Flow Meters
Trust Sump Extension
OS Giken Twin Plate Clutch
NISMO Timing Belt
N1 Water Pump
JUN Oil Pump
NISMO Engine Mounts
NISMO Gearbox Mount
Trust Clear Cam Gear Cover
Cusco Master Cylinder Brace (painted black)
RacePace Custom Oil/Air Seperator - Mark II Design
APEXi Pod Filters
APEXi Power FC Pro
Turbosmart eBoost
Tomie 260 poncam's (needs to be installed)
HKS GT-SS Turbos
Port matched Exhaust Manifolds
HKS Dump Pipes
HKS Front Pipes
3" Cat
APEXi GT-Spec Cat-Back Exhaust
18x9" 5Zigen Wheels
265/35ZR18 Bridgestone S03s
Tein FLEX Coilovers
Tein EDFC Controller
AP Racing 6 Pot Calipers
Brand new 330mm DBA Rotors w/ aluminium hats
Ferrodo DS2500 Front (Road)
Ferrodo DS3000 Front (Track)
Ferrodo DS2500 Rear (Road & Track)
BF Goodrich Braided Lines
Motul RBF600 Brake Fluid
Recaro SR-3 Drivers & Passenger Seats
Genuine Series 3 Xenon Headlights
Brand New Nissan Under-Bonnet Pad
NISMO Bonnet Lip
NISMO Rear Wing Ornaments
N1 Front Bumper Vents
If you have any questions about the car please feel free to contact me on 0414 99 53 91
As for asking price i'm not sure what this car is exactly worth given all the work..
I'm in Sydney btw
I just saw the rules, i'd be looking somewhere in the 40's...
Edited by kabab
https://www.sau.com.au/forums/topic/162621-r33-gtr-1997-vspec/
  • Replies 44
Kabab,
I normally dont post in for sale threads like this, but I had to....
Man, that is one awesome machine - best, tidiest GTR Ive seen for a long long time
No doubt the new owner wont have to spend a cent on it, everythings been done that needs to be!!!
As for price - obviously its insured? Maybe similar price to the insured value?
Oh, as for my buying it, the mrs would...well....dont go there :)
Sweet ride once again mate,
Chris
Kabab,
Chris
Actually the cams need to go in its got stock cams atm.. I've got the poncams in the garage those alone will add about 40kw and give more mid range... Its fairly cheap to drop them in as well..
Its all ready for NOS to i have the bottle in the garage as well :happy:
Its insured for about 50k
Forget the misses :D
More pic's
Edited by kabab
ahhh Andrews old car....
I have seen this car in the flesh a few times and I can say it is one of THE cleanest 33 GTRs out there..
Andrew was a very anal....owner :) and im sure you were as well :P
Being a 32 and 34 follower I wouldnt normally consider a 33 but for this car I would make an exception :glare:
Goodluck with the sale, im sure the new owner wont be dissappointed
i drove 600km today - all the way to canberra and back with a BIG fat deposit to put on another car.
to cut a long story short - walked away very dissapointed.
so im back to square 1 - shopping AGAIN! - where in sydney are you located as id love to come and see your car?
Edited by 350z
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
