  • Replies 47
i say: "meh"
agreed!
they already said that the possibility of a tsunami hitting the coast of Northern QLD is very unlikely, let alone hitting the NSW coast, but need to issue the warning because it's still possible.
https://www.sau.com.au/forums/topic/162826-tsunami-warning/#findComment-3022556
$10 says its a fizzer
The NSW State Emergency Service advises that:
· People at the beach should probably have sand castle building competitions also maybe bury each other up to your heads in the sand.
· People in boats in shallow water should immediately start drinking champers. It'll be an awesome adventure of alcohol and tidal waves.
· Boats and ships at sea should move to shallow water and aim for beach goers.
· · If you see the sea go out like a very low tide then immediately go to the shore and take a closer look. Its an phenomenal site to see and the closer you are the better.
· People should keep listening to the local media for updated information so they can use this event as an excuse to get off work for a day.
This warning will be updated by 1pm EST.
https://www.sau.com.au/forums/topic/162826-tsunami-warning/#findComment-3022701
