Hey guys,
This probably sounds stupid but how exactly tell the difference between a series one and series two R33 just by looking at it. And is there a difference in performance between the two?
Thanks,
Sammy.
https://www.sau.com.au/forums/topic/163075-how-to-tell-if-r33-is-s1-or-s2/
Hey guys,
Thanks,
Sammy.
A series 2 from the front the Bonnet/ Grill is different, The headlights are a different shape and the front bar has those round fog lights and indicators in it. A series one has that funny grill with emblem on it and less angualr lights
From the rear the series one has that low rounded wing whereas the series 2 has a higher squared off wing
No difference in performance
PS prepare for heaps of people to tell you to search
There is little or no difference in performance between S1 and S2 (other than the wear and tear resulting from the fact that S1's have typically seen a few more years of service).
From memory, these are the main differences...
Interior:
Updated trim
Updated instrument panel
Passenger airbag
Exterior:
Round indicators and foglights
Sharper bonnet lines, grill and headlights
Chrome backing on headlights
Chrome 'S' Skyline symbol on bonnet
Color coded 'Skyline' trim under boot
Titanium coloured boot lock
Squarish rear spoiler
Mechanical:
Updated ECU
Nylon intake wheel on turbo
Updated ignition system
Different CAS for post Sept 97 models
There is a thread somewhere on the forum which has a detailed list of all the differences between S1 and S2 - do a search.
post up the interrior pic, pic of the gear shiift surroud and the dash surround
i think series 1 have the coin slot on the dash
series 2 have the coin slot on the gear shift surround
at least I think thats how it goes
you dont have a S2 unfortunatly, its a S1/.5
S2 are 96-98 models S1 are 93-95
Ummm no. u are wrong... very wrong, mine is a 95 series 2.. November build...
stick that up there.:)
OK so what series is this one...?
Yrs is a so called 1.5 dude
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
