yes, but they all all via PM, which stops the board getting clogged up with every Tom, Dick and Harry's f/s items, and back and forth banter. I will delete this useless topic shortly too ....
https://www.sau.com.au/forums/topic/163272-for-sale-thread/#findComment-3029881
maybe the for sale section should have a delete option for the person that started the topic so when it is sold he or she can delete it themselves?
Only admin & mods for that section are allowed that privilege & you'll have nil chance getting them to enable the option for general members to delete their threads. But, as the creator of a thread you can just amend the topic title & state item has been SOLD. :P
https://www.sau.com.au/forums/topic/163272-for-sale-thread/#findComment-3031492
seems too much hassle tho. no one that does it the first time will ever do it.. need to have a system in place. maybe just open up a ForSale section like the events section and then u can place the threads in the section of various items... 1 item, 1 thread, like the big for sale section.
https://www.sau.com.au/forums/topic/163272-for-sale-thread/#findComment-3031604
