O/K I see. That setup would require a realitively high pressure strut to work at such a tight angle, unless the bonnet fibreglas or simmilar. I took the measurements for mine off a Camry (distance from pivot points etc)
  • Replies 47
Posted Images
So has anybody had a stab at a 32? im curious as i had a professional strut guy have a look at my GTR and he reckons that there isnt enough room in there for struts to fit. Tein dont sell struts for 32s. (not that ive found anyways.) Nengun only sell Teins for 33's.
Kezza, long time mate. if you get a chance to have a crack at this, can you let me know pls? i wont be getting my car back from getting the rebuild for another month.
wogboy, you're actually very right sayingn that about the angles. The tein kits are pumped up mega strong.
Arep - strut guys don't know shit (beleive it or not). When I first went onto this quest, I asked a couple of them. This one guy was an absolute wanker bogan, and was really rough, and goes oh, what we'll do, is i'll make up some brackets, come down and try it on the car, then i'll adjust the brackets, come back again, i'll finalise them, then... I was like f**k off (i lived about 75 minutes away - I'm north he's south). Any reasonable fabricator would do it on the spot.
Some other dumbass was saying nah, you only need 1 strut. He was planning on putting the strut going from the strut tower, to the front of the bonnet! the point of these is to make more room, not to make some spastic sort of contraption.
Or why don't you ask rice extreme customs to make a set for you, or do they sell em?
tein do make r32 gtr kits. that is your bestoption
Edited by MANWHORE
yea true. this strut bloke was pretty dodge. he said it wasnt worth it cos they wont fit. there will be no room for the bonnet to close.
i do like how wogboy has his setup though. back where they are has them out of the way and no damn bonnet bar in the way when workin on the front. plus they look stock as. ill hafta look into the more when i get my car back from the rebuild. Cheers
  • 3 months later...
  • 4 months later...
Any progress?
only skimmed over page 2 but has anyone suggested the mounting point off a VR-VS dunny door for the ball on the gurad, they have a right angle mount with the ball hanging off that and the mount could be attached via the 1/4 panel bolt.
i am thinking of just getting some strong right angle metal and laying it over the side of the bonnet so i can attach the bonnet ball to the instead of directly to the metal.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
