  • Replies 133
Before you buy your BIG turbo have a read of this: Programable ECU Vs Factory ECU
This is very important and can save your engine, but the choice is yours. A programmable ecu also extracts a lot more potential from your stock turbo and the bigger turbo.
Do you already have; the fuel pump, rising fuel regulator, injectors, min. 3" exhaust from turbo back with hi-flow cat. and muffler, H/D clutch, etc? If your are missing any of the previous get these first as your 4K will not get you far without them.
With 300rwkw you will also require forged pistons, conrods, etc., if you want a reliable engine.:uh-huh:
my 2c,
GOOD LUCK!
Alan
I think $4k won't be enuff to get you to 300rwkw. Do you also have $4k for the suspension/handling setup because you will need it in order to put that 300rwkw to the ground.
You gotta be thinking 50% power and 50% how the heck am i gonna use that power not just boost boost booooost.
Edit: btw pm on icq again i think i lost your uin.
Edit2: Now that I think about it
Suspension - $1500
PowerFC - $1800
Tyres - $1200
= $4500
and you would be doing well to get 200-210rwkw from that. Your going to need atleast a $7-8k budget i think.
300rwkw for 4K, I wish life was so kind.
You have cooler and exhaust, you will need:
Clutch (twin plate) $1200 plus fitting
Injectors $1k
Fuel pump $300 plus fit
ECU fitted and tuned $1.5k plus
EBC $500
Turbo $2k
fit turbo(new lines) $500
New manifold $1200+
Dump pipe $350
Wastegate (perhaps depends on turbo) $5-700
Pipe from pod to turbo $150
Fuel pressure reg $150
Now you have a problem with either:
Rebuild bottom end inlcuding remove and replace engine: $7k+
or
Head gasket to decompress engine $600+
Fit head gasket $300.
It would also be nice to do the cams and cam gear, add $1.5k
This is without upgrading any suspension or wheels which you will definately need to do. You could probably get away without major brake upgrades, but expect to need some decent pads and upgrade your brake fluid to dot 5.1
Add another $1.5k plus.
If you want to maximise your $4k -
get some decent coilovers, and swaybars. Any power you make can be optimised by getting it to the ground well, without decent suspension you will find with 300rwkw, that cars with much lower power will hand you your arse.
Get a decent ECU - power fc, or if you want cheaper, the e-manage is cheap enough that you can get it fitted and tuned for about 1.5k. Add an EBC and you will have a different car. You would probably at this stage be wise to do your clutch, IF it is still holding, it wont for long. A button clutch should do the trick, or an upgraded organic - hopefully, if you shop around, your funds might just cover this much.
300kw what is that in hp.
If i was 1st i would get the block pro tune so u can crank some killa hp and the car can handle it.
Also u better upgrand brakes and all that shit first no point having a fast car if you can only turn a coner at 20km and takes 100m to stop the car when u r going 100km.
By the way does you car have a saftycutout best get that removed before u add hp
Injectors $1k
EBC $500
Turbo $2k
New manifold $1200+
Dump pipe $350
ahaha life is tough with a turbo car, only going to cost me around $5,000 -> $10,000 to pull a nice 500rwph on my 88 vette (when it comes)
Common soulja, "ahaha life is tough with a turbo car, only going to cost me around $5,000 -> $10,000 to pull a nice 500rwph on my 88 vette (when it comes)"
Plus $5K per year in fibreglass flexing repairs......
Bin there dun that
Bin there dun that
:):(:O more like $3,000 for body parts + shipping + import tax + installtion + repainting = $$$$$$ more like $10,000
I'd lower your expectation and go for 250rwkw to start with.. if you get that, then you can start budgeting for 300rwkw+ later on. The reason i say that is that 250 it seems a lot more achieveable is that a lot more people reach that goal without touching the internals (if you're fairly lucky), and without running massive boost.
If you get (or at least quite close to it) 250rwkw, you might be able to get by with your standard injectors (save $600-$800), a cheaper clutch, cheaper turbo (highflow, or GT30) , and lots of things.
There seems to be a lot of disagreement that u can in fact do it... But i am sure $4k budget is achievable.. for at least 250rwkw anyway.
250rwkw will be a bitch if u floor it off the line I'd say, but you will notice that extra power without having to too nuts on full aftermarket suspension and things.. some pineapples and at least some good rubber for your rears (why go four 4 expensive tyres where its a RWD afterall) is a start. That should get you into the 12s bracket if 1/4 mile is your thing - as long as you can drive well.
If you get the power then find you hate how its delivered then I guess you consider the other bits - don't go too nuts all at once.
Good advice, could you imagine jumping from ~180rwkw to ~250rwkw hell i'd wanna have 4 pairs of undies let alone going ~180rwkw to ~300rwkw.
Im stayping put at 203rwkw for a little while. Starting to work on actually putting that to the ground and also stopping.
Pickup my new DBA Club Spec Rotors today (dremen take note) and also next on my list is a set of FM901's in another month or so (hopefully before rego).
Please give us a run down on how you would achieve this.
Have you driven a 250rwkw skyline with sock suspesion and wheels? Dude, even with 200rwkw and a decent power band, you will have dramas with stock wheels and suspension. 250rwkw would be an absolute danger to yourself and everyone else on the road.
IMO, this is one way you end up with lethal cars on the road, building an engine, but not taking care of the rest - very, very dangerous. Beside that, what would be the point in having a car that if you try and drive it at any more than old mole pace, you just go around in circles. I have seen this done with a old ford 351 GT. The novelty runs out pretty quickly when your car cant safely be taken out of the street and into traffic. Have you ever tried to corner a car (from a stand still) that has no traction?
But please Predator, I would be really interested in hearing how you could achieve what you are suggesting.
Guest INASNT
I am upgrading to about 250-270rwkw at the moment and i have budgeted around 5.5k (which included selling of my old parts), outright its costing me around 7.5k for the initial outlay and thats without forget psiton, short penned rods, portedhead, new cams or any other engine work.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
