  • Replies 133
What about this:
Ben,
Thank you for your enquiry, we can do a high flow to your turbocharger but it is a little more involved than a standard turbocharger, this is due to the fact that your turbocharger is ball bearing and has a ceramic turbine shaft. The rebuild / hi flow we carry out to these unit are as follows:-
Turbine Wheel - replaced and upgraded with a inconel(steel) wheel , either stage 1 or 2
Compressor Wheel - replaced and upgraded with T04 wheel, either stage 1 or 2
Bearing Pack - replace with an XTR ball bearing package
Turbine Housing - machine to accept either of the larger wheels
Compressor Housing - machined to accept either of the larger hi flow wheels
Wastegate Actuator - standard or upgradeable to have higher boost pressure as standard.
Costs - Stage 1 = $2250.00 Rated @ 400hp
Stage 2 = $2450.00 Rated @ 450hp, does require other mods i.e. intercooler, fuel, etc
These prices are for the turbocharger only, but remembering that in effect the turbocharger centre will be brand new and the turbocharger will bolt straight back onto the engine with all fittings.
I trust this answers you questions, please do not hesitate to email me again.
Regards
Your standard turbine housing will not let you flow enough gases to push past 200 rwkws.
Sorry better explain...
When they profile the housing to the wheel they are only opening up a small part of the housing, the actual size of the standard R33 turbo scroll is absolutely s**t house.
I dont think hi-flow is a very good option for 250rwkw...
Dremen if you are interested in going a GT30 i can FAX you a dyno plot, the reason why i cant post is coz i dont have a scanner.
true.
when they hi-flow (my understanding i could be wrong) is mill out the intake/front housing a little bit to get a better/bigger wheel into the front. They don't actually change the housings.
Don't know what they do about the exhaust. Maybe the same thing???
please correct me if i am wrong.
When they highflow they do the following:
Originally posted by DREMEN
At the moment I am running 179rwkw and thats not enough for my liking...
Gimme a call then and i'll show u what 203rwkw is... a noticable difference from 192rwkw (after i got the exhaust done down at Cobra's). Still though i personally can't even feel the difference between 192 and 203 but im holding onto the steering wheel.
I think you'd have your balls in stitches after getting in a car with 240-250rwkw. No point aiming for any higher.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
