Hey guys
I just received my nismo fuel pump from nengun and am wondering if i should install the little fuel relief valve thingy ,its says on the nissan box "A VALVE CUT" , im not sure exactly what it is and what it does but im wondering if i should install it or keep the stock one, if i need to install it were does it go?
I need to get this pump in tonight so if anyone could please reply to this thread and let me know if i should use it or not that would be great.
Thanks alot
Jason
https://www.sau.com.au/forums/topic/163855-nismo-fuel-pump-for-ecr33/
Not 100% sure but the guy who did the DIY thread on the Tomei pump had the same valve and i believe he didn't bother.
Apart from pump brand, the kit is similar to yours and has the same parts.
last i was there, it was lurking in the first page of the DIYs
How much was it?
'98 R33, nice one brother !
How much was it?
Hey mate
Yea i saw that DIY thread and the guy didnt bother installing that valve, but it must come in the kit for a reason, i dont think they would put it in there for nothing, anyway i will start doing the pump tonight and if i can see were that valve goes (Im guessing its just a replacement for the stock valve) i will put it in, but if i cant find were it goes i guess i will just leave it out, unless someone can tell me if it need to go in and were.
It cost me $420 nzd shipping if i can remember right, i choose it over the usual bosh/walboro setup as its a straight no hassel bolt in setup.
Cheers :blush:.
I think i remember seeing them installed between the pump and the screw-top for the tank..ie just above the pump itself if anywhere.
I just ordered the Tomei pump today too for the same reason as you.
Well, actually the main reason is the no noise factor.
It will run completely silent due to the ready made bracket and rubber housing.
Looking forward to putting mine in too :laugh:
I installed it on mine, it worked for approx. 30km then I pulled it off the road to do more stuff to the turbo etc.
I think/thought it was a non return valve to stop your fuel line from draining back into your tank but when I blew into it it didn't do anything so FIIK. I thought it would valve off and on if I blew into it??? I had to put it on line on a bit of fuel hose.
Hmmm its interesting to see that some people have used it and some havnt, in my opinion the "relief valve" must come with the pump for some reason surely, it would seem strange to me if it didnt have much of a purpose.
Also the valve has a threaded end (it is a male thread, the thread is on the outisde) on the bottom of it like it is meant to screw onto something which i thought was a bit strange, maybe it will all make sense once i pull out my stock pump.
I bought a Nismo pump and I never used the pressure relief valve either (partly cos i couldn't figure out where to install it). I had the same questions about why they would include it if it wasn't *really* necessary.
From what I could find out, and as mentioned, it is installed to prevent the fuel from draining out of the lines. But, I guess that what your fpr is meant for too. The only other thing I could think of is that it would slow the draining of the fuel lines when the engine is not running?
Ok, what that valve is, is it's an anti reversion valve. What it means, is that when you turn off the car, the fuel line stays pressurised. If you don't have one, then you'll have to turn your car to on, let the pump prime, then start it. Otherwise, you'll need to press the gas a bit or it won't start.
The stock setup actually has one of those valves already. I suppose the reason why they supply you wiht a new valve, is because they expect that you'll be running more pressure/flow with the new pump, so maybe the new valve is better at handling that. Having said that I have used the stock valve, and haven't had any problems.
However, as it's there, I don't see why you would not use it? lol.it's just like howit comes with a new gasket, would you consider using your old one? What will you otherwise do wth the new one? sell it? lol
oh ok, that's interesting food for thought jase. I know that nissan is renowned for part sharing (all car manufacturers are). Just a guess, since s14 injectors and r33 injectors are the same. If the part numbers are the same, maybe that means that nissan went lazy and reused the exact cradle on both cars :P
who knows, all that I can say, is in regards to the valve, if I got a nice shiny new valve, i'd be like you beauty and pop it in anyways :O
Well ive just finished installing the pump :), was rather easy, only main problems i had were, took a while to actually find the right spot that the pump bracket mounts to as you cant really see into the tank so i had to just go by feel, took me a while but once its in the right spot you will feel it click into place, 2nd problem was trying get the dahm plactic screw on cap to go back on, in the end i got it on but that also took a while. those two things were the only main problems.
Now to the "relief valve",i decided to use it as it obviously came with the pump for a reason, so i followed the instructions/diagram on the instruction sheet which showed that you have to cut the standard "pump to feed line" at 260mm , this is then were you put the "relief valve", this is obviously why 2 new nismo clamps come with this kit as you need a clamp on each ends of the hose for the relief valve , i couldnt find anywere that the relief valve would screw into (remeber that it has a little thread on the end of it), so it is just hanging in there , this is most likley why nismo give you a specific measurement as to were to cut the fuel line, possibly so that it wont hit the inside of the fuel tank etc etc, i had a good look/feel around and the relief valve was far from hitting anything).
So to sum it all up it was a very easy install ,the car runs like stock and you cant hear any difference at all, i would reccomend this pump to everyone :), I would chose this pump over the usual walboro/bosch/gtr fuel pumps anyday, for a little bit of extra money your getting a pump that is hassel free to install and comes with everything you need, no mods required!
Edited by nizmo_freek
As a matter of interest, how muhc was it, and where did you order it from?
I know that the tomei pumps also come with the anti reversion valve, new tank seal, hose clamps, pump, and bracket.
Did the nismo pump also come with the bracket/cradle? or did it fit the stock bracket?
would you by any chance have taken a picture?
The nismo comes with the bracket, it would fit the stock bracket if required, but its not needed, the bracket supplied is exactly the same as the std one. I had a walbro on mine, and changed to a nismo, I sold the walbro with the bracket and all as a going concern. Ooh and I got mine from Nengun, can't remember how much, I think around $350.
Just checked, now $386 delivered.
