Hi guys,
I have a set of nismo engine mounts and a nismo gearbox mount for sale to suit BNR32 GTR. I think they may fit one or two other models of skyline but I'll check the nismo catalogue tonight. They are brand new, in the box. pick up from me in sydney or post wherever at your expense (i think it's about 4kg all up). I'm asking $320 for the set. These are an important upgrade if you have increased power (well torque really) over standard and are even more important if you plan on any track work as the engine rocks on it's mounts quite a bit and worn engine mounts can cause other problems (like broken front diff - ask steve n1GTR about that!). Plus nice new, stiff mounts will give you a small benefit of extra response as normally when you mash the throttle some of that instant torque is lost in deflecting the engine mounts, with stiffer mounts this torque travels through the drivetrain instead. no pics, but they are nothing fancy anyway. I guess I can take some pics tonight if needed.
They fit R33 and R34 as well. R34 has a slightly different standard engine mount design to make it easier to work with them but both types fit. Nismo engine mounts for BNR34 are the same as these.
geez, don't all beat the door down at once. how about $300 for all the mounts (2X engine, 1 X gearbox)?
Hi Richard,
i sent an e-mail to Greenline for a set of these middle of last week and haven't had a reply as yet. So there loss is your gain.
I've also been looking at your wheel nuts to so might as wheel get those too.
Can you get a price for freight to Perth (6109) for the mounts and nuts and pm me the details.
Cheers
Paul
Hi I sent a PM about a week ago on these.
Havent heard back.
But then Ive looked in my PM folder and It didnt store the message.
Give me a call
Dominic
0414 62 62 43 or pstrata @ tpg.com.au
Im in Sydney
yeah, my mistake. dominic was in first. I just hadn't replied to him. so they are sold to him.
sorry for the confusion guys, just a bit of brain fade on my part.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
