Me, im farking useless. Will give Toms camera back tomorrow and let him sort it out. :(
Also, big thanks to Tom for seeing that i got it home ok with the latest in high performance square Flintstone Tyres :rolleyes:
Thats it for me tonight. Much scotch to drink..then have to go and knock on neighbours door. She will think im dead sexy when banging on her door at 2am with a raging home grown :)
  • Replies 237
Posted Images
Damn, i leave early and i miss out on TB doing something special with something fixed. I had the best view today, being on the start finish line. I must admit, while i did'nt see any Vortex's being generated from nay cheater cars, but Riverdance's. Ferni's, Jacks and TB's car sounded very nice!!! That Datto got my vote FTW!!! But i do love the sound of a good rotary!!! :rolleyes:.
And that Lotus was fun to sit in, but i'm tipping anyone would look cool sitting in it, even teh Fonz would struggle to look cool getting out of it :( Lambo is tehporn!
Congrats to everyone for putting in some great laptimes :D I was pretty happy with my 1.26 and with a bit to learn around corners 2,3 and the last two corners onto the straight there is prob a high 1.24 in there somewhere.
Time to get my susp. sorted and bring on June :)
...and again, see the times Riverdance is doing on street tyres! Dispelling some of the thinking about how quick you can go at places like Sandown / PI etc on street tyres.
You can add Handbags doing a 1.27.7 in the S15 to that list as well.
I want to thank everyone from SAU who helped out and made the day run smoothly.
Your help is greatly appreciated by the both SAU and WRX Club, as without the assisstance of volunteers, the day would not go ahead.
It really is great to see so many SAU faces who are willing to donate their time and help out at these events.
Thanks again to all.
Also congrats to all the drivers, some great lap times and some great viewing as well.
instead of being a second faster this time I was a second slower... just wanted to go quicker than James in the EVO and ended up getting steadily slower all day... trying too hard and my brain may have fallen out sometime around lunch... I have decided I need more power to make up for my lack of skill haha:)
sad to see the 32 dented Troy... some good times were put down in the afternoon, congrats to everyone who set pb's
What a great day it was..
I enjoyed helping out and would do it again..
Well done every 1 on there lap times.
Troy :) (THE KING OF SPIN)
Ya shot past Mav and i at like 200 and in a blink you were doing 360s.. It freaked us out
Thanks for the show.. Will buy ya a beer for that 1.. :D
But damned if i wasnt going to do a 1:22 with the same basic car i came from NSW in. So it looks like next time at Sandown the car will have some gear that will make it easier/safer to drive...and hopefully quicker
...saddest thing is that no other sane person will let me drive their cars again :( I had to run off and prove im a hack :ninja: Video will be up over the weekend sometime
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
