Hi,
I need to get a new clutch and need help figuring out which is best for me :P
It's to find a new home behind an RB20 with near enough to 200rwkw. It will mainly be street driven, with a stint at the track (circuit) here and there. I tend to give the clutch a kick if i'm out of the power band and need to go in a hurry while cruising, and I currently have an organic faced exedy with a 2800lb pressure plate (so a heavy pedal doesn't bother me).
So basically I want something that doesn't sacrifice too much driveability, and will go the distance...
Also needs to be on a budget, so I think a Jim Berry is out of the question.
I've been looking at the Exedy clutches sold by forum traders,either the Organic faced clutch, or a cushioned button clutch.
How 'bitey' are the exedy cushioned button clutches? I've read through the drivetrain section and found a few conflicting reports (some say OK, others say difficult to master). The 'bite' wouldn't bother me so much, but i won't be the only one driving the car, so i'm looking for a compromise.
What other brands would be suitable for around $450
Thanks in advance,
Michael
https://www.sau.com.au/forums/topic/164091-clutch-options/
I've got a cushion button put in my 33 towards the end of last year i think, drives just as fine if you ask me, seems a bit lighter though. Had a organic clutch in it before the cushion button but something broke and wanted something better and the cushion button was the next thing to get otherwise i would have been going for a twin plate or even triple plate clutch but my mechanic told me it would have been overkill. Think it might have been about $400 something, can't remember at the moment. Would have to check my receipts. From what i was told a cushion button is better than an organic clutch and then better than that is a twin plate. Choice is up to you...
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3042270
i've used 2 excedy brass buttons and both were a bitch to drive, was either on or if and if u tried to slip it u'd carve its life span dramatically!
jim berry does a cheaper option aswell. give him a ring and also NPC a ring and see what they can do for you.
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3042367
oh and i've looked at the lightened flywheels, but for an outlay of $400-$500 it doesnt look like i'll be going that avenue right now. I'm hoping to pick up a spare (stock :blink: ) flywheel and have it machined and ready so I can do the swap over a weekend.
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3043311
oh and i've looked at the lightened flywheels, but for an outlay of $400-$500 it doesnt look like i'll be going that avenue right now. I'm hoping to pick up a spare (stock :wave: ) flywheel and have it machined and ready so I can do the swap over a weekend.
i have one here all machined up. send me a PM
also when u speak to jim, tell him shane with the gtr who he's doing the sachs clutch for put u onto him :blink:
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3043376
Just got off the phone to Jim...35-40 mins :stupid: great guy to talk to, really does know his stuff.
Shane your flywheel is a week away :glare:
The best option for me will wind up roughly double my budget, but the step below may be up to the task for a little (few hundred) over budget (though the lesser one wasn't his recommendation). Gave me a lot of info to proccess.
He also suggested that one major brand of clutches had a "dud" diaphram.
anyway...a lot to think about :wub:
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3045176
Just got off the phone to Jim...35-40 mins :glare: great guy to talk to, really does know his stuff.
Shane your flywheel is a week away :(
he certainly does, and even if u dont buy his gear, u come away with some great info to think about and to help you make ur decision :(
haha thanks for that, saves me ringing him on monday :stupid:
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3045276
i probs would have gone JB if he were in melb. i ended up getting an exedy cushion button with lightened flywheel 3 weeks ago. the drive home from the shop was interesting. would bite like a mofo. bunny hopped it 90% of the time i took off. it seems to have bedded itself in now and drives almost like my old standard clutch just a tad heavier. it has developed this slight rattle down low in the rev range in 1st and sometimes 2nd for a sec. i think it could be the lightened flywheel or my dodgy short shifter. anyone else got this problem.
so are you going with the JB clutch? and which brand has the dud clutch?? not exedy i hope...ha.
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3048262
I've decided to go for a cheap & nasty clutch for now to get me back on the road (exedy Organic HD).
My car's been off the road for long enough though. The modified Exedy I've got in there now lasted me ~4yrs @ stockish power, so hopefully a new one will last at least long enough without abuse to get the engine project off the ground (fingers crossed :) )
basically I could buy 2 cheap exedy clutches for the price of one of Jim's well-regarded products, and though the quality may not be comparable, you can't ALWAYS have the best of everything!
If the new motor gets off the ground, i might look at one of Jim's clutches then :)
Thanks for all your help!
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3052205
Hi,
Thanks in advance,
Michael
i got an xtreme cushion button clutch for 500bucks and was told by the mechanic and the clutch place that they can take upto 250rwkw, good for street and the occassional spirited drive, drag, drift etc...
so far the clutch is going well..highly recommended
imo, changing the clutch over is a very labour intensive job if you need to get it done professionally then i would suggest go for a good clutch as there is no point getting an "ok" clutch when its going to cost u around 300-350 bucks for the labour. i read above u can do it urself so that shouldnt be a problem. imo i just think get the clutch done right the first time with the clutch u want. no point getting a clutch that isnt up for your power level.
just my two cents!
hey mate,
when i got my cushion button done, the clutch showed the same symptoms as u. it was very bitey and needed it to be slipped it at around 1500-2000rpm during take off for smooth take off. now after 10,000 or so kms it has bedded itself now. i think the rattle down low is a common thing for heavy duty clutches as ive been told by a mechanic its just the clamping and unclamping of the heavier pressure plate. though i dont tend to hear the rattling, clicking noises when i change gear in a specific rev range...only when its down low.
cheers!
Sorry for the long post
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3053250
wow....10,000kms? Ive got an exedy 6puck and its shudders like all hell anything under 2k, so it might get better further down the track? as ive only done 6,000kms odd so far...
But then again ive been told theyre sposed to do it? Because theyre meant for high rpm launches etc..
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3053506
just my two cents!
hey mate,
cheers!
I'm going to be installing it myself, so doubling up on labour at a later date doesn't bother me. Initially I was considering a button clutch, but decided I want to away from it for driveability reasons. Jim suggested that if I won't be launching the car, be it at the drags or the track, I shouldn't need a button clutch and the organic should be sufficient (that was before I mentioned that i hope to have more power in 12+ mths).
So for Exedy's Claims I think the Organic HD will be sufficient for my car's current power level, so long as I don't abuse/slip it.
So ultimately it will probably mean that I'll have to buy a new clutch before a new HD Organic one wears out, but it does mean that I'll have my car back on the road sooner rather than later :)
https://www.sau.com.au/forums/topic/164091-clutch-options/#findComment-3054266
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
