Hey fellas, just a thread introducing what I've been doing for the last couple of months.......
Picked this up for a low $350.00 about 5 months ago with the intention of it being a full on drift car......to look at this its nothing, yet.
1989 R31 S3 Exec, Auto, 255,00 odd k's on it with a blown head gasket.
It was straight, bar the front 2 panels and a few shopping trolley dents.
First of all out the engine and trans came along with tailshaft and exhaust.
I manualized it pedal wise
Then removed sound deadning and placed carpet back over the top
Next a nice little seat installation and my good old elevo drift wheel, bit of a copy of the sparco.
Did a bit of work for my sis so she bought me this 600x300x76 cooler
Rb20det Silvertop and 5 Speed box with loom, blitz access ecu and Extreme HD clutch
And in she goes
R32 generic intercooler kit plumbed up
Old suspension out ready for D2 A31 Cefiro Coilovers, s13 Sr20 Brakes Hubs / Uprights and S13 Control arms
Gauges - oil temp, water temp, boost
As it sits as of yesterday now on work stich 17x7.5 215/45, and rears 17x8.5 235/45
So overall -
D2 A31 Coilovers fully adjustable 7/5 spring rate, with s13 sr20 brakes, hubs / uprights and control arms
rb20det silvertop conversion with r32 5 speed box (manual tailshaft bolts straight up)
JJ fixed back seat with auto gauge gauges
r32 generic intercooler kit
17" Work Stich rims
lots of little bits ive missed out on.
Heaps of stuff to go, next is minispooled diff before practice in may, after that hydro handbrake. (hanny should be in before may school all going well)
Cheers for taking the time to read this old skyline thread ehehe. :(
To date the car has cost me $4,989.00 So not to bad for what it will do. :(
Edited by evsr31
https://www.sau.com.au/forums/topic/164353-my-track-car-build-updates/
Yeah thats what minispool does, its a bit chunk of steel that you put in the centre of your diff replacing all spider gears etc, equalling a locked differential.....but im sure you knew that. diff is an auto ratio 3:9.1 But I want pinty ratio 4.11 ehehe.
Power mods in the future
rb25 sliding hiflow
040 fuel pump with surge setup
and remap...should see some half decent power figures.
General Mods / Work to do
Minispooled diff
25mm bolt on's all round from wheelworx
Oil filter relocation kit with oil cooler setup
New hot pipe
Bleed front brakes
Whiteline swaybar front / whiteline strut brace
Dual rear swaybars rear
3" exhaust with straigh pipes, currently exiting at the dump (yes its nice n loud)
Flush cooling system
Hydro hanny setup with vt rotors / calipers
Hook up water temp sender
Body Work
CCS Skirts / rear bar, or Laurel Skirts / rear bar. And r31house front lip copy.
I had to do this writeup really quickly as I'm at work so missed out on a few things.
These d2 Coilovers are great, damper adjustment does quite a bit but on full damper its bloody hard, card wont move its just tyre flex hehe.
Hydro setup ill be doing with a mate and just getting the master cylinder / lines from powerbrakes, we have a template for the bracket so just involves a bit of welding and brake bleeding.
One of my coilovers top studs at the top in the front is missing so if anyone knows where I could find a replacement the same or similar please let me know.
Also need a stock r32 hotpipe, coming off the turbo compressor housing that goes to the stock intercooler inlet side......if anyone on here has one please PM me.
Cheers for the nice comments, More pics as progress / budget allows. :P
Edited by evsr31
yeah Pinny crown gear and Pinion would be cool.....but its not on my top of the list to do.
Hopefully with 1 bar of boost, very free flowing exhaust, fmic and remap it should make around 165 - 170rwkw....so should be aight.
Mates made 170rwkw with same mods.
WTB -
r32 stock hot pipe off turbo compressor housing
Camber top stud (1 of 3)
Edited by evsr31
Nice car man iv seen the build up on 31skylineclub.com. Im also doing up a r31 s3 rb20det silver top for drift and road use might see you out on a r31 cruz or track when i get her painted.
Edited by cruzin33
Not too hard mate, back needs custom top hats or u redrill the strut tops to fit 2 stud.
Fronts u need s13 control arms, hubs / stub uprights and your selection of brakes.....s13 sr20 calipers / rotors are what ive used.
It's all bolt in basically, fairly easy to do.
When you do the s13 conversion will it change the track of the wheels(the width from wheel to wheel)?
Yep track is changed, its wicked....more track the better hehe.
The s13 control arms are the main factor into it having more track. They are significantly longer.
http://forum.r31skylineclub.com/index.php?topic=69648.0
Thats a thread showing how to do the conversion. :bunny:
Oh before I forget, few kinda daylight shots......
Cheers, ev.
Edited by evsr31
think its 10-15mm per side extra track, wont do boot and roof black because a mates is like that and it will just look too similar.
Also major factor you have to consider is wheel offset too, and the amount of camber being run giving it a bigger traction field on the tyre while cornering.
Edited by evsr31
farken sweet car, but those coilovers are fkn shite. ive had to send more back than we sold i rekon..... one set even speared into a evo bonnet!!! strut top broke and the shaft kissed the bonnet.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
