Hey guys, im getting my car fixed after the last drag day when my clutch let go (or whatever it was that let go) and im going to go out and buy all the mods now so i can do it all at the same time. Basically im only posting this because im not sure on the "detailed" information that is needed for mods such as "what cc injectors" or "which cams to get". Ive got a 5k budget including tune + labour.
So what im after:
- i want to have not much more then 300rwkw
- want to hit a high 11sec 1/4 mile, car has run a 12.3sec as is
- keep in mind it will be a daily driver as well
- i want turbo lag to be minimal with a good strong mid range punch
What i currently have already (that would make a difference). currently running 250rwkw (dyno sheet is in the RB26 turbo upgrades sticky):
- mines ecu
- full turbo back exhaust
- slide hi flow rb26 turbos
- k&n panel filter
- os giken twin plate clutch & flywheel
- hks evc 3 boost controller @ 15psi
- splitfire coilpacks
- JJR hardpipe cooler kit
Im pretty happy with the brakes & suspension setup i currently have, got a few upgrades to make here and there but this is excluded from the budget.
This is what i have planned so far:
- power fc - ~$1500 inc tune
- injectors (what cc/brand?) - ~$1000 installed
- fuel pump (looking at a bosch 040) - ~$400 installed
- cams & cam gears (type/brand?) $?
anything else ive missed? i dont think i will need to upgrade the air flow meters for the power im after (under 320rwkw) and i dont really want to open up the engine other then the cams, unless something is really needed.
Thanks guys.
https://www.sau.com.au/forums/topic/164549-what-can-i-do-with-~5k/
  • Replies 45
5k? Thats more than you need :closedeyes:
PowerFC - $1500
Injectors - Nismo 550/555 - PT# 16600-RRR60 - $750-$800, then whatever for installation
Fuel Pump - $320 installed i wouldnt pay anymore than that for a Bosch pump install, its a 20min job and the pump costs $220
Adj Cam Gear - $200 installed
Tot - basically 3k
You might have a 100 here or an extra 100 there. But 3k will get ya over the line without a drama.
Nismoid I think your a little under with the Cam gears quote. 2 gears and instal at $200???
AFM's are not needed for what his chasing. I would not be worried about cams either and like others suggested use the money on a decent set of tires if you havent already got them.
Seen good and bad tunes coming out of bel as of late, dunno what the go there is. I fixed up a tune on a 180sx today that was done there, Owner was most disapointed in the results.
Edited by Risking
I did say give or take a 100 here or there (just add 100 on if thats the case)
Cant be spot on everything all the time :P
Modified stock ones IIRC are $150 i can get them for.
Not sure if thats RRP or whatever though, i dont stay on the prices all the time ;)
PowerFC - $1500
So you wouldn't bother with replacing the fuel rail? air filter? or even replace stock flywheel & clutch?
PowerFC? I've never heard of it (Being new here and all), so I'm guessing that is an aftermarket ECU right?
Mark. If take the time to read the first post, you'll see the parts that hanyou already had on his car.
These include a better clutch, panel filter upgrade among other parts.
These were left off the list because he does not require them.
If you have never heard of a PowerFC, i suggest you spend a lot more time reading. Its the most common choice of ECU on a Skyline :nyaanyaa:
And you certainly dont need to change the fuel rail for 300rwkw. I wouldnt even bother changing it for 400rwkw.
Good point, sry just got caught up in your posts. Well I'm going from a VL commodore to an R34 GT-T, so, there 'might' be some similarities, as the VL had the RB30 and the R34 the RB25neo. Yeah sry mate, just getting a tad overzealous, I did in fact read the first post. I've been reading a fair bit the last two weeks on this forum, so I kind of gathered power FC was an ECU, I asked only to make sure...
just to confirm, the bosch 040 will be sufficient to hold the power? how much can it take? as im about to buy one now.
just orderd a set of the Aerospeed cam gears on the group buy as well.
edit: never mind im actually going the nismo or tomei fuel pump for safety.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
