you take two pictures
one with bonnet on and one with bonnet off
using photoshop you 'cut' the bonnet area (can be a bit bigger as its all the same anyway) off the photo with it on, and transfer it to the pic with no bonnet
as it is a different layer, you can use the eraser or blender tool to remove the bonnet layer and make it look like the bonnet has a hole in it
tada....
Edited by 342Four
ive never done it like that lol!! eraser is only one pressure and wipes it all out >_<
use layer masks with the pics and blend them together with an air brush - comes up with a mad effect (especially where you want to blend the bonet with the engine at the edges) you just generally have more control over the picture you are putting together.
layer masks are a MUST if you want them to turn out as best they can :mellow:
hope this helps!
ive never done it like that lol!! eraser is only one pressure and wipes it all out :P
layer masks are a MUST if you want them to turn out as best they can :P
hope this helps!
what program you using? no need to use masks or anything like that dude!
try adobe photoshop you will not go back!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
