there is an r34 gtr in perth running a Trust T88 turbo and a nismo plenum, so i dont understand why you shouldnt
Hmm, how about because they cost a large lump of money & don't do a great deal to help your motor.
Things to think about:
1. The most convincing reason to run a single throttle body is to allow a MAP sensor to work in a more stable airflow environment, ie allow it to work better.
2. If you are running AFM's the half the reason disappears.
3. What else can you do with the $1000 odd dollars?
4. As mentioned the closer the throttle butterfly(s) are to the motor itself the better the throttle response will be.
5. The Group A cars ran the manifold with out mods so how about "It was good enough to win three SATCC's & two Bathursts" as an argument?
6. I think bkc meant coherent rather than cogent. To ne a cogent reply would entail it having a persuasive argument in one direction rather than the more balanced approach that was taken.
This money of them it needs the hunk and the flag & Dob respects your motor and because it does not do with the proposal the Hmm, as summary. Approximately will think,:
1. It works inside the air current environment which is stabilized and the ie and understanding the reason which runs the agency body which is simple works well and it it puts it permits the map sensor.
2. When you run the AFM anti- and the reason disappears.
3. It spreads out what of that outside and $1000 odd it is and in the dollar to do it is good?
4. When being under referring, compared to, kkap in agency butterfly (s) motor form compared to sickle agency answer back.
5. "Regarding it 3 SATCC's& 2Bathursts" it was winning enough it is good in argument and to peel as group A it ran the multiengine like this from in the mods which it kicks?
6. Me by the bkc the cohesion characteristic which means rather it is appropriate and it thinks. The answer which will be appropriate connecting was rather adopted the assertion convincingness inside 1 direction it it is compared to process percentage approach head percentage theyn the place.
Fixed.
Check out Hypertune for their plenums as all of the current fast GTR's run and the soon to be returning GTR-700 use them.
They come in 90mm and 102mm. hope that helps
Thank you very much .
thank you so much for your time :)
Fixed.
I am sure that took quite a bit of effort. It demonstrates that you are a very strange man.
or, to put it another way
Effort large conform to taking. Personage for not ideal unstrangeness.
I don't understand what do you mean!!
The trust T88 , 1050 hp muximum but nismo plenum 650 -700 hp air input nearly !!!! :)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
