many late nites researching this forum and many overtime shifts at work got me my parts...and ive only added half of it. Kinda hoping i would get some feedback from people that have actually had their engines rebuilt.. When everything is done and up and running then i'll came back to this thread and add my experince and hope it will help someone else in the same boat
  • Replies 44
how come nobody goes to an engine builder directly and only recommend workshops who in turn palm some of the work off to their machinists?
surely it would be cheaper to go directly to the one place and cut out some of the middle man?
Im not stating anything, im curious to know
There is virtually no Japanese performance workshops in Perth who do everything in house.
XSpeed, Hyperdrive, Top Racing , CRed, Speedworks, Ovaboost , In Tune all outsource the head work and engine machining.
All the above workshops then assemble the engines in house to there own specifications which vary with each shop.
The engine machining and tolerances supplied by the workshop is one of the critical factors in engine life and building one to go racing and will be refreshed after every season is different to building one that is in a street car.
The only shops that machine AND build engines are very limited , both in quality and there desire to involve themselves in turbo cars. Most of these shops deal with V8's such as Kostecki, Kendrick, Repco, Veems , Performance Automotive plus others I can't remember.
Cheers
Ken
ahh so what youre saying is you tell the machinists the clearances/tolerances required for the block depending on pistons chosen, head w/ squirter sizes etc and theyll do what theyre told, otherwise theyd be having a stab in the dark?
that makes sense since it isnt common knowledge
thanks for clearing it up ken
Cheers
Ken
you forgot to mention nobody will touch any head/block that has had work done elsewhere and needs assembling :blink:
  • 8 months later...
Hmm,
I decided to do my RB25det myself...
Find out a bucket load of stuff that I never knew about engines too...
If you have the motivation, and the time give it a shot... I found that building the bottom end all the stuff has to be perfect (obviously) but yeah as long as you can find out all the specs for the block, and pistons etc, take the bottom end to the machinist, with the clearances etc, and they will set it all up for you to those specs..
But yeah if you got the money to spare give it to someone else.. I am interested in this sorta stuff, as my full tme job is in a completely different field..
I got accesss to a workshop where I am working on the engine evry day from 3 till about 6.. except I have access to it for half day on sat as well.. Having the support of a mechanic (mind you he does bmw's and merc and all the euro cars) he is still able to give me some pointers.. There is enough info on Skylines australia to be able to do all this, there is torque settings, all the measurements etc, to be able to do everything..
Will let you all know when it is finished, but so far the pieces are falling into place.. But yeah I am glad I decided to do this, as I have only one person to blame if something goes wrong... But yeah I know it won't...
Cheers..
Edited by maka
  • 2 months later...
got my r34 in at top racing. rb30 bottom with the NEO head. Engine came back from engineering last week so steve should start bolting it back togther this week sometime. I went all out on this project for big power. t04z (1.00) a/r with 2bar should see 650rwhp....Haven't factored the NOS system either :)
other mods:
poncams 260
greddy plenum
port/matched/polished head
sard 1000cc
cp pistions ceramic coated
argo rods
fulyy balanced
HE sump
ati balancer
plus much more
yeah hence my 1st post saying if ppl have actually gone to an engine builder.. seems like no one has!
As stated, nobody in Perth does it all themselves.
I just had mine rebuilt and found these guys to be exceptional:
Headwork: (re-shim for 270 deg cams, 10.8mm lift, and fit new guides/springs, assembled and decked -- $1100)
Applied Automotive - John St, Bentley.
Block machining (re-bore to 86.5mm, acid dip, etc etc -- ~$1000:
Performance Modifications - Osbourne Park
or
You can use these people direct, then take your machined block and assembled head directly to any workshop in Perth, and they will build it for you. There is nothing magical about building a motor, and no reason you couldn't do it yourself with the right tools, time, and patience.
People who I've seen build motors which stand the test of time:
Ant Scali (X-Speed)
Sean Keating (All-Star Garage)
There you go, thats all the advice I can give you. Coming from someone who's just built a motor (and made over 530hp at all 4 wheels) it might have a bit more substance than someone telling you that you should use their workshop because they're yet to try anywhere else and thats the 'only place they trust with their car'.
i wonder how much i would of saved if i took the head and block directly to the associated workshops. As with one of the workshops mentioned, was told of 3 month waiting period. Although my repeated calls were never returned and got the cold shoulder ended up at top racing. Also good to go to the different worshops and have a chat with them. Have a look at how the shop is run and the people that work their should give a indication as to how good they are
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
