Hi im looking to get some new rims some time soon. I have a R33 GTST series 2. The car is silver
The things i want in a rim is -
Got to be 18s
Got to have HUGE dish
Got to be as wide as possiable on the back
Not to BLING BLING
I at the moment i have white 17s AVS ultra light rims. i wouldnt want a rim to heavy etc.
Do you guys n girls have any ideas? Or do you have any rims on your car that fits my criteria? Please put pics up!!!!!
Cheers
https://www.sau.com.au/forums/topic/164761-rims-with-dish/
  • Replies 50
can you send me a couple of pics of your current rims? I might buy them off you if you wanted when you get some new rims.
Cheers!
Do you have an email address i could send the pics to?
edit go to this lik these are my rims on my car
http://www.skylinesaustralia.com/forums/in...p;#entry3023786
Edited by Adz2332
https://www.sau.com.au/forums/topic/164761-rims-with-dish/#findComment-3052697
not really a fan of those starcorps heavy and bad quality have heard some bad stuff good for the price but a bit common, also if u have a budget of nearly 3 grand you surely would be lookin at something from the land of the rising sun probably forged. i picked up some Weds sports rims recently not commom and look great. Bet you could find some nice Volks or something along them lines
https://www.sau.com.au/forums/topic/164761-rims-with-dish/#findComment-3053193
Isnt that against the anti-bling bling criteria?
I have seen them in 22's on a VE commodore, looked really good. 18s would be a bit small i think, they may loose there wow factor, 19s might be the go?
only problem 19s are a defect! but also on the skyline they will have big dish unlike the comadore
https://www.sau.com.au/forums/topic/164761-rims-with-dish/#findComment-3054270
Just remember this with dish. The rears you will have no problems finding a nice jap wheel with good dish, but at the fronts, if a wheel has too much dish, most likely it won't clear your front calipers. Unless you start flaring your front guards, you will be hard pressed trying to find good dish for the fronts.
Few wheels to consider, Volk GTC, Work VS KF, Traffic Star DTS, Work Meisters, SSR SP1...the list goes on :whistling:
https://www.sau.com.au/forums/topic/164761-rims-with-dish/#findComment-3055810
I've never heard of that before. :whistling:
So biggest legally you can get is 18"? Some cars come factory with bigger than 18" though.
Not sure about the rules in SA, but in QLD as long as the rolling diameter does not exceed 15mm you could even go 20s and still be legal.
https://www.sau.com.au/forums/topic/164761-rims-with-dish/#findComment-3055829
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
