hey guys,
I'm just wondering who with r34s on here have experienced bad coils? I've searched around and found problems with a missfire in the 4000 to 4500rpm on turbo cars but what do NA symptoms have? how can u tell its a coil and not a plug without physically inspecting it? reason I ask is mine is running like a dog (sounds like a WRX) and there is a lot of stuff to unplug to get to the cam valley to check.
so any help on what the symptoms are would be great I suspect its a coil but need some reassurance.
thanks
https://www.sau.com.au/forums/topic/164961-bad-coils/
NA's with bad coils experience the same problems as their turbo counterparts. My last car was a ca18de and i went through about 12 coils on it. Car feels like it's missing a cylinder and sounds like a wrx but without any pull. There's a few threads on coil maintenance and cleaning, check them out.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056087
Also can anyone tell me it is a coil from my symptoms?
Cold start is fine will drive around OK for a long time or short time its totally random. Engine light comes on car sounds like a WRX has poor accelertation etc. But when it is driving OK it does have a miss as well?
Any help would be great
Cheers
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056886
Generally speaking, nissan coils generally get worse when they're hot. On my previous car, when the coils were bad they would generally be okay for about 30 minutes then it would sputter and the engine light would flicker as you say.
How many kms has your car done? has it ever had the coils replaced? I would definately give it a good clean, take out the carbon deposits on the tip perhaps give it a light sanding, silicone the boots and clean the leads. Come back and tell us if that helps solves your problem.
Investigate the possibility of going to splitfire replacement coils... I wish I had known about them earlier, that would've saved me going through a dozen coil packs.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3056997
Thanks again Howie will give that ago. Car has done 60,000k's Can they go around there? I have heard R34's are notorious for coil failure.
My first set went at 68,000kms on my last car.
It's not just R34 notorious for coil failure, it's basically any nissan car pre-2001 that uses the coil pack system. CA/SR/RB's.
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3057103
ive had my r34 for 7 months and had 3 coils go on me. in the end i replaced all of them with splitfires. its too costly too continue to replace each coil as they go. my r34 n/a has done 67,000. the last 2 times i lost the coils the car would be running on all 6 cyclinders, then lose a cylinder then gain it back etc. those two coils where showing a greater heat resistance to the others. hope this helps!
https://www.sau.com.au/forums/topic/164961-bad-coils/#findComment-3057915
  • 4 weeks later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
