We sell them for $150. As we have just finished a new mould, fitment is very good. We have sold numerous wings to members on here too.
The original design was by Signal Auto in Japan, since then they have gone under several different names; drift wing, stealth wing, etc.
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3058451
I have seen them over $250.
$200 delivered is a pretty good price and psi parts dont sell shit either, its good quality.
Ive bought parts from other places or second hand and they dont line up properly.
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3058511
Less than $200 delivered (depending on where you live) is our normal price, we always keep these in stock too .
For reference only (please enter your postcode into our shipping quote link on our website for an accurate cost):
Melb: $38.57
Syd: $42.28
Bris: $53.06
Ade: $42.28
Perth: $76.30
Hob: $68.75
Link to the product on our website: http://www.psiparts.com.au/front.asp?pid=8...oductID=WGDTR33
Be cautious of undercoats, they are usually put on to hide defects in the fibreglass from the moulding process. Most spray painters will use a specific undercoat for the type of paint being used anyway. Thus a gel coat is the preferred option.
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3058703
Good info there... Food for thought...
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3058734
same also applies with the GMH black on the inside of kits... PMSL when i see that...
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3058755
whats the mounting like with yours??
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3061622
I'm assuming you are referring to how ours mounts? It has two indented strips along the width to allow for some double sided foam tape (or similar) to stop the wing bouncing or moving, and will require some self tappers to scew directly into the wing itself through the original boot holes. I'll try to get some pictures up shortly.
Also be sure to use silicone or some sort of water proofing on all holes to prevent seepage into the boot and rust forming.
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3061685
Ill have a close look at yours at the skid pan Dan...
Id like to see what they look like from the top/side, i mean like if you standing at the drivers door looking back at the wing???
And you were saying they use the standard wing holes, so I can put the stock wing back on if I wanted without having to bog up any holes. IE. Bolt on and bolt off...
https://www.sau.com.au/forums/topic/164996-r33-drift-wing/#findComment-3063220
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
