ok dudes, here are some pics of my new ride.
hope you enjoy. ill keep updating the photos as i go.
cheers
Details:
1997 S1 Stagea
Dual sunroofs
full leather interior
electric seats
17" R33 GTR wheels (gutterbashed to the shithouse lol)
Alpine 3 Stack in dash CD player, TV/DVD thing that doesnt work atm
it has that automatic locking boot thing....
absolutly love it at the moment, and its a massive change from an r32 gtst.
In the future, i plan to do the following:
Full exhaust
get it lowered
SAFCII or AFC neo and tune
SITC if i can find one
possibly a FMIC
and a slight boost increase....
sorry for shit photos, i dont work very well at 7am in the morning.
https://www.sau.com.au/forums/topic/165030-my-stagea/
Nice, I love the red but its a pity it fades so bad with time. Thats with any red though.
What'd set you back locally?
yeh, ill try keep the polishing etc up so it doesnt fade...
it cost me $16,300 with a years reg and rwc. also has all the import papers and he gave me 6 wheels (4x stockies and 2x work wheels) everything he had, he gave me for nothing.
Loks Nice Jarryd.
Damn you, you also got S2 tail lights.
Now we need to organise a Melb Stagea Cruise.
PS. I hate you Jarryd lol I was meant to be the only melb member with red
yes, melb stagea cruise is good idea.
and lol, im sorry.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3059507
hee.. no offence but are you asian ? the numbers 888 on the plates mean " I am stinking rich "
nice car.. cant wait for ours to arrive! its in brisbane now.. so should see it in a month
I have yet to learn all the subtle differences in the S1 and S2 stageas.. but I Will get there eventually.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3059793
yeh, im a n00b when it comes to stageas
maybe we should start our own club? :D
nOObies of the world unite!
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3060002
Nice mate, good work.
Not bad a price, interesting actually, I scored my S1 dayz 2yrs ago for $17800 (didnt get extra wheels, lol)
that was with catback exhaust, pod, apexi boost guage and solenoid adjusted to 10psi
Good pickup there in my opinion.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3060034
and lol, im sorry.
funny you should mention polishing my observant wife noticed just recently on the net somewhere it's not advisable to polish cars with sfhc, be interesting to see if anyone can shed any light on that.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3060334
Nah, thats a bit of a crock, you can polish SFHC (Super Fine Hard Coat - its a clear coat paint treatment put on in the factory. If you Stagea has it SFHC will be on your back window at the bottom) What you need to do though, is stick to pure wax type polishes and avoid the buggery out of anything even mildy abrasive. The abrasive cuts into the clear and leaves really nasty swirl marks in it that you will never get out. Mind you, I have never actually polished mine and the water still beads every time it gets wet so I don't see much point.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3060351
good onya dale, wasn,t sure if it was just bullsheet or not, you seem to know your car care(re: roof-rails)
ps mine still beads after 2yrs.
https://www.sau.com.au/forums/topic/165030-my-stagea/#findComment-3060376
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
