  • Replies 42
Dropped in some cams. The car drives much better than before. Better mid range and top end. Boost level is maxed at 18 psi. The GT-SS turbos are great for the street and daily driving. good response and power band. My last car had twin top mount turbos and made more power but i actually prefer this set up as the power is so usable and alsmost instant. i have had 2530's too and i can say that this feels very similar but with more response.
HAHAHA....... Denote the NON-sexual manner! hahah just incase!
Just a question for widebody how many times did u get pulled over by the cops?
haha its an awesome ride and did u get pulled over a few times or take it for a run?
p.s GTauto did my gearbox conversion too - greeat workshop if u have a gt-r
sweet car widebody, I love my gtr.
would you say the gt-ss turbo's are maxed at the 300awkw mark or do they still have a bit in them?
also, my ignorance- but where's the GTAUTO workshop?
It's right behind mercury, about 2 streets away off newmarket road. It's on edmonstone street, I forget the number and from memory you cant see the number of it cause it's a fair way from the road. Just remember if/when you do go there to drive on their driveway really slowly! it's got very deceitful speedbumps and I bottomed out on one cause I didn't see it ;)
There there shane, its ok...
:Col strokes shane in a calm non-sexual manner:
i get "pwned" all the time by you lot, but its starting to become soo repetative i'm finding it funny :yes:
got them slicks yet? if you need a hand hooking up that nos system give me a yell
oh and b4 i forget, when u want some1 with half a clue of how to pedal it, send me a PM :domokun:
P.S please dont ban me :D
Awsome, but something tells me you will tinker with it... :)
Good to see you return to the dark side, let us know when you take delivery (I assume youll be buying an R34 GTR) ;)
Tinker - maybe... hehe
Already have it, yeah it's an R34 V-spec, white with Gold 19" Rays Gt-c rims....
I'm a Nissan man deep down, was always coming back!
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
