Hey guys
just letting ya know, that this turbo is on its way and going on my car soonish.
Along with Tomei 1.5mm Head Gasket and Arp Head Studs
Tomei Poncams
I know its going to be laggy, but it sure is going to be fun when it hits full boost.
I chose this turbo as it was cheap and have heard a number of ppl whacking out some good figures.
I have at the moment on the car:
PFC, AVCR, FMIC, Nismo FPR, 555cc Inj, Z32 AFM, Split custom dump to car for the gt3540.
3" Exhaust(removed 2nd muffler) Hiflow Cat.
Without getting into internal engine work, would there be anything else that i could consider to put on, that will help to make the car reliable, stronger
and better to drive (Less Lag)??
The gt3540 turbo is off the XR6T and has the .84 rear housing. I did ring GCG and ya can swap it for a .63 housing but the .63 housing costs 750. And im like noooo thanks. So i will see how this goes.
https://www.sau.com.au/forums/topic/165673-gt3540r-iw-on-its-way-r33-gtst/
  • Replies 78
Hey guys
Tomei Poncams
I thought all the XR6 Turbos that come on those fords were the 1.06 exh housing..? bigger exh for the 4ltr motor or something..who knows should be fun wen it comes on though
yeah i thought that the xr6t were 1.06, but yeah who knows could of been swapped. unsure what happened.
just hope it doesnt do anything stupid. i know i shouldnt be asking this
but i have seen alot of ppl making over 300rwkws with these, with just cams and fuel mods and ECU etc.
What would be a suitable boost pressure to run through it and still be safe, and safe for the engine. (whats the limit)
anyway as it has been cleared up there that XR6T have a 1.06 rear housing.
would there be any other mods to look into to help with lag, and car being more streetable.
also in previous post what boost to put through the turbo?????
It's all about cubic capacity. Being down on swept volume by 1.5 litres compared to the Ford means it will require extra rpm, but it will also take a lot more rpm before it runs out of puff. Changed final drive (diff) ratio may provide a fix.
The other would be to use a 3 litre bottom end.
Then there is the option of laughing gas :laughing-smiley-014:
Overall, it's like trying to wear size 12 boots when you've got size 10 feet. Not as good as it could be, and it won't feel nice until it's changed for something with a better fit. Oversized turbine housing for an application will result in lazy response.
The boost question is relative to how much power you want to make. What is your target?
Edited by Dale FZ1
Dangerman4 runs a GT35r .7 comp .82 IW rear BUT he runs an tough Auto which makes a huge difference to spool.
GCG do charge quite a bit for the IW housings. I was quoted $800!!!
Bill at ATS in Adelaide wants $500 for the IW housing and will give you $100 for the old XR6T 1.06 IW which brings it down to $400.
The .5 comp cover will help improve response/spool in the lower gears as well as improve the mid range once its on boost.
A mate of mine is swapping out his GT35r .7 for the .5 on his RB30det as to increase mid range (make it a little more savage as it comes on boost) and spool in the lower gears.
Shall be interesting if the theory of it all pans out in real life. The blokes over on xr6t forums state when swapping up to the .7 they loose the low/mid range shove but it has a little more top end (when pushing over 340rwkw).
well, pretty much i was looking at as much as i can get without affecting reliability too much.
is it a big job converting the bottom end with the 3L, cause i know ya can pick them up cheap as chips, but just fitment and etc.
might looking into it later on.
but back to the power question if i get 300-350rwkw i'll be happy, but making sure its done safely. if thats possible.
what i will do is see if i like the way it goes firstly, if i dont like it i will speak to ATS and get the smaller housing.
if then i still dont like it, or get bored, i will look into swapping the bottom end with the 3L.
Any more info is much appreciated, should be on the road before june.
Thanks
Thanks
Reliability wise...
300-350 = BOOM.........
If you have a 100+mm FMIC and a nice exhaust manifold and even a plenum then i'd run 18 psi and around 22 / 23 degrees ignition advance will see you to 300kws
if you dont have a nice I/C, manifold etc then you may need 22 - 25 psi and 17 - 19 degrees ignintion advance to make 300kws
time will tell as all engines are different but that gives you something to aim at.
standard cams i made 317rwks but that was up near 26-27 psi with 18 degrees ignition.
But running a auto sucks some power so your outcome may differ.
cheers
Darren
you wouldnt happen to know what the snout size of the turbo is on a 0.50 ar compressor cover.
Havent got the turbo yet, waiting for it in the post and want to buy all the silicon hoses and shit for it.
3 inch
With regards to silicon hoses.
I bought all my stuff from http://www.siliconeintakes.com/
Absolutely stoked with the quality and service. Very quick postage from the US. Took 5 days in total.
I bought all mine in black
4" Joiner (turbo to turbo pipe)
4" to 3" reducer (afm to turbo pipe)
2 x 2.5" joiners
90degree 2.5" to 2" reducer elbow
All up inc postage it cost me $100 AUD. Which is cheaper than I could have obtained those parts here in AUS.
It was a real pain in the arse to get all black from a local company. Some had one bit another had the other.. Real pain in the arse not to mention expensive when you factor in multiple postage.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
