  • Replies 135
Alll I can say is WOW!! That is super hot sexy fun time
ASL???
Still no undies...
Like I said only those that can fill them out to just cars liking get them :rolleyes:
aww man yer not much room for my willkins :< it poked out the top :O.. mite be a good pressy for my gf 2morro for our anniversary :unsure: wo0t!!1
ha ha I like your style!
hey i thought id just make a post seing who else got them selves some awsome pair of blue undies from just car insurance... i was so excited i got some new undies in the mail just to find out they dont fit.....
thats soo wierd! obviously justcar thinks that its customers are not packin enough heat!
PEOPLE.....HONESTLY!!!!
PICSORBANNNN!!!!!
hahahaha.......
I WANT MY UNDIES!
I don't replace mine often... am a boxers fan anyways, most of my pairs are prolly 5-6 years old :( Any undies have got to be better than the condition most of mine are in (I'm banned from walking around the house without REAL shorts on)
I WANT MY UNDIES!
Unless you look like you are 12 I can tell you that these wont fit
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
