Ok non related, but ive got a 33 gtst and des the same thing until it reaches operating temperature, unmsure but couldnt colder plugs ie: 6's 7's heat range would give same result until temperature reached the normal range, i have also found that it is only until normal temperature ie: 78-80 deg on pfc hand controller is reached that the issues dissapears,
Interesting will keep an eye on this thread
  • Replies 46
Yeah its weird
Cause i would have thought the power FC would use almost identical cold start maps as the OEM ecu nad would use the coolant sensor. It runs brilliant cold on the FC.
Maybe its not the sensor itself, but a little further back at the input into the ecu or something?
you really want to check the coolant temp sensor. this sensor is used for fuel enrichment when the engine is cold.
chances are its stuck at a hot value (resistance) and the car is running real lean when its cold.
can measure the resistance of the sensor with an ohm meter with it disconnected or use a volt meter with it connected to see if its in spec, but either way from your description this sounds the culprit.
Can the CTS get stuck at cold value? I have a new coolant temp sensor to put in to try and solve my fuel consumption issue.
I blew a fuse on my thermo fan circuitand the car got pretty hot a few weeks back , wondering if this shagged the coolant sensor.
I got mine from nissan for $71 in Randwick - will post a part number up later.
Just a question though, is your plug for the CTS brown? The replacement I got has a blue plug, but the one thats in there now is brown
i've sent cash0 a pm regarding testing of the sensor, so we will have to wait and see if its the problem in this case.
No worries, I thought it was easier to buy a new sensor for $70 than it would be to test the old one - that way at least I know it should be good for a while to come (yes I am lazy).
Ok, I've checked out the coolant temp sensor with a multimeter and here are the results:
Dead Cold (<10deg): ~3.5k ohms
Hot: ~1 - 1.5k ohms
The specs for the sensor as provided by RB30-POWER:
20deg water temp 2.5k ohm (or 2500ohms)
80deg water temp 0.3k ohm (or 300ohms)
So, a little off - but it certainly doesn't look like it's stuck on a value.
Curiously though it did run quite well this morning after I tested it, maybe a dodgy connection? Anyway I'll keep a monitor on the situation.
  • 1 month later...
Hi there,
I'm another victim of the infamous three legged billy goat when running cold. Exactly the same symptoms and also stops immediately when hits temp or switch engine off and then restart. I have also cleaned afm's, changed plugs, checked coils also have done the injectors. I invested in a consult cable and software and nothing really stands out, you can definitely see some weird behaviour as a result, but nothing obvious malfunctioning, no strange voltage readings or faulty instruments, well ones that the software reports on. Something to add is the other day the NDS (Nissan Data Scan) registered that i had a tps (throttle position sensor) and an ias (intake air temperature sensor) error, now i cant remember which one but one of them had happened 37 times. My battery too is now sounding a bit tired and have no idea how old it is.
Dying for a result on this one, been driving me crazy for months and months now.
Cheers
Andrew
Drive around with it cold
Let it run like a billy goat.
As soon as it gets good, jump out of the car.
Unplug the Coolant temp sensor that heads to the ECU.
This is the plug that sits on the top radiator hose, and has TWO wires going to it.
See if it runs like a dog or not.
If it does, most likely CTS.
it hasnt happened for 37 starts of the engine, not "its happened 37 times". ie big number = long ago = not an issue now.
if an error code is 0/1 starts ago, then its probably something that needs to be looked at
post consult logs
Hey there,
Unplugged the CTS and it made no difference, if anything the car ran slightly better, not sure. I must add though that the car wasn't misbehaving this morning, that shouldn't matter though right? I will gather some logs together and submit them. Your help would be very much appreiated.
Cheers,
Andrew.
Edited by Twitchy
Hey guys,
Me 3, when cold it feels restricted. I have to put my foot down a bit more just to accelerate. Same thing with the switch effect, gets to middle of the gauge then runs normally.
Qu: My 32 GT-R doesn't take very long to reach running temp, real quick, how long is it taking for you guys?
I have done a bit of reading into this and I have found an article saying that "the standard R32 GT-R's ECU had a miss when the engine was cold". I think that it may have been miss-interpreted as a miss but is really something else, not a dead miss, more like a restriction. This would explain why having a Power FC would fix the problem, which I have also heard about. The article that I read made out like the factory ECU has a problem, which was known about.
Another probable idea is that the ECU is running with the cold engine maps, rich mix. This would also create the same effect, however, like you said, the PFC runs fine on cold start. Perhaps it is programmed differently or as above it may suggest that the standard ECU has a fault.
  • 3 years later...
old thread but saves me starting a new one about the same problem im having
past few months ive noticed when i first start the car in the morning, everything is fine, idles perfect, no misfire etc
i let it idle for 30 or so seconds then begin to drive, this is where the problem start,
it hesitates/stutters/lack of power then as the engine temp needle starts to rise everything runs 100%
i thought it was my afms so i bought new r33 gtr ones, problem still there
just chcked my water temp sensor and it registered 3.5k ohms dead cold....yet to get a reading when hot
what else can it be its realy annoying !!
ive noticed if i let my car idle for afew mins so the temp rises abit, i can drive off with no problems !
im pretty sure its just the ecu going into cold start mode to prevent you doing any damage to the engine
i agree with this person :)
Edited by AaronNM35
i had a problem similar to this when i first bought my gtr, replaced the old bosch spark plugs that were in there to ngk's and the cold start is flawless now
hmm funny you should mention this, the car had NGK iridiums in there when i bought it, few months ago i put fresh ones in, exactly the same ones gapped to 0.8mm, im pretty sure the problem started around then, might be worth pulling the new ones out and put the old ones back in and see how it goes
thanks !
im running stocks bov's
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
