"Dear valued customers and members
We at JDM Imports had temporarily ceased trading
due to some unexpected issues abroad. These problems have now been resolved.
Any rumours of us no longer in business should be dismissed.
We are currently on holidays until the 15th of January however we are available via email
until we reopen in mid Jan. Any fresh orders and enquiries are welcomed at any time.
All enquiries can be directed to [email protected]
Any followups of existing orders can be sent to [email protected]
Any complaints or concerns can be sent to [email protected] or via PM as i
will personally attend to any issues.
Sincere apologies to all of those that have had problems contacting us over the Christmas break.
Thank you for the support from many of the members here on SAU and we will endeavour
to sustain our untarnished reputation amongst our existing and future customers.
Kindest regards,
Charles"
That was on 7/1/07 though, he only made 2 more posts on nissansilvia this year and is no longer a trader.
  • Replies 46
...dont say that... cmon, im barly scraping $300 a week... legal help?? :closedeyes:
CJ
Not joking !
I have pursued them through the CTTT here in NSW and requested their presence for a tribunal hearing which they chose not to show up for.
The hearing found in my favour and issued a court order for JDM Imports to pay me back the money they owe me.
Here's hoping the legal system works ! I would suggest you do the same and hope for the best.
The costs to get things under way are not much but will take ages.
Best of luck !!
http://aca.ninemsn.com.au/
Send them your story with details of how various ppl have been ripped off and how much you are owed..I'm sure the ACA would consider your story seeing as you even have an address you can lead them to and phone numbers the ACA can leave messages on. You should hopefully get a reaction from them if they realise this is going on national TV.
this may or may not help... but i have charles's msn - he hasnt been online for months.
but in the case he does here it is: [email protected]
spoke to him extensively about trying to get some wheels organized and i didn't really trust his character and never went through with it.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
