  • Replies 78
You're sure there's no EPA fine? I'm positive there is...
have you EVER heard of anyone coping this 10k fine for having either no cat/s or screamers? and if someone did get the 10k fine, the whole community would know.
it's just a big scare tactic, and all you'll get is a defect notice advising you to change it, if ur unlucky enough to get caught
Irrelevant, it's still illegal and whoever the stupid prick is who's the first one to come whining on the forums deserves what they have coming.
The EPA has very strict rules on emissions and the fines are enormous to stop people from running any vehicle outside of the clearly defined legislation.
De-catting and screamers should be for track use only, anything else then you deserve to be pinged.
let me guess, ur also a member of greenpeace? :)
i think you'll also find, if you did ur research, that here in qld they dont do emissions testing
Track use only? Let me guess you have a 92db - 94db exhaust system with a cat :laughing-smiley-014: have fun with that restrictive little system.
Why do you care so much what other people want to run? I maxed out a non industrial DB meter at 130db, so sue me? The guy asked where he could get a vented screamer pipe, not reasons why he shouldn't.
Key words "where to get them" not "tell me why I shouldn't"
Edited by Nismo_Boy
If it matters, I have a legal exhaust with a metalcat... while it's no track monster it's certainly not gutless (250rwkw).
If Skyline owners are going to so careless about adhering to the law in this regard, don't we just have ourselves to blame when wondering why we're targeted as hoons? :) I for one hate the old POS silvia who cruises past my house daily with a 100+db milo tin, does nothing but give the rest of us a bad name.
To my knowledge QT used to carry out spot checks on emissions - mainly targeted at vehicles running Super - aside from that I'm not sure, have never been defected.
Also, before bitching that I deviated from the OP, note that I merely followed the direction the thread was taking.
soo then why dont the harleys/motorbikes and v8's get this 'hoon' tag aswell?
this is pointless argueing and we're just gonna get warned or some crap lol
there's been 2 names given so give them a ring champ :)
You contradict yourself. Hooning and a loud exhaust is not one of the same, although I will admit at times they attract the attention of police. Shiny = bad = he must be a "hoon". I'm not condoning people should run non complaint exhausts, I do as its my choice, like wise with the person who asked where to get a vented screamer pipe.
I could write you a half page news paper article theory on hooning, why it started and how its protraded now. However it has nothing to do with this thread, just like everything else in here albar the phone numbers on exhaust builders.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
