the fine is $10000 for u and $40000 for the wprkshop that did it. or something like that
What part of max fine don't you understand.
I received 1 point and $75 and had to take my car to the Police once I had the exhaust fixed to clear it.
I ended up just de registering the car as it was sold anyway and paid the fine :)
  • Replies 78
and yes, i'm having screamers and no cat's :)
Your my hero shane :)
If you want have a screamer that the average grunt wont be able to spot get the outlet extended to run along your exhaust so it looks like it comes back plumbed in. That will confuse most piggys however noise pollution fines will still come!
If you want places, any custom exhaust place will do them for you. CES is one, but its better just to get a split dump that is plumbed in n e way, as there is no real perfomance gain out of them, and atleast it solves all legality reasons, if you want noise get the right exhaust and the right material for the exhaust if you want more noise get stainless intake pipe and apexi pod that way you can be happy
Good luck
Oh please get them shane :) VOTE 1 dob shane in for undue noise :) j/k
Good luck
there will be flanges and removable section to make it legal my dear boy ;)
oh and Vote 1 dob adam in for bald tyres and pollution with his excessive overfueling! :P
I ended up just de registering the car as it was sold anyway and paid the fine >_<
did u get fined by the cops or was it the epa. if the epa go over ur car u will find that i might be right
does any1 know where to get the already made 1s?. just jap was meant to be getting them over 6 weeks ago but doesnt look like there coming.
i cant send pms now for some reason. i write it out and push send and it doesnt com up in my sent items and never get replies back so id say they dont work. may just be this computer
improve gas flow
I mean to ask why does he need one... What makes him think it will help...
As an external venting wastegate pipe from a stock turbo will not seal properly from the main dump...
It will affect the back pressure on the turbine and hence cause it to take longer to spool. So infact it will not improve his situation...
Also its highlly illegal...
shuddup fool and let the man have his fun ;)
maximum of $10,000.
same as having a gutted cat.
emissions, flames, noise pollution...
ah crap. even before the engine build i had a no cat, flames & well over the legal db limit. I really wanted a screamer but i guess the amount of defects my car will have i really dont need the extra attention. I know sau doesnt support defective cars but i know i'm not alone on this situation
Import Auto Parts. i believe sells split dumps he might have have screamers available..dont know.
Yes IAP or Banzai Parts Garage or if all else fails ebays your good friend....or maybe look at classifieds on this website. They pop up quite a bit. Expect to pay around $250 plus!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
