the fine is $10000 for u and $40000 for the wprkshop that did it. or something like that
What part of max fine don't you understand.
I received 1 point and $75 and had to take my car to the Police once I had the exhaust fixed to clear it.
I ended up just de registering the car as it was sold anyway and paid the fine :)
  • Replies 78
and yes, i'm having screamers and no cat's :)
Your my hero shane :)
If you want have a screamer that the average grunt wont be able to spot get the outlet extended to run along your exhaust so it looks like it comes back plumbed in. That will confuse most piggys however noise pollution fines will still come!
If you want places, any custom exhaust place will do them for you. CES is one, but its better just to get a split dump that is plumbed in n e way, as there is no real perfomance gain out of them, and atleast it solves all legality reasons, if you want noise get the right exhaust and the right material for the exhaust if you want more noise get stainless intake pipe and apexi pod that way you can be happy
Good luck
Oh please get them shane :) VOTE 1 dob shane in for undue noise :) j/k
Good luck
there will be flanges and removable section to make it legal my dear boy ;)
oh and Vote 1 dob adam in for bald tyres and pollution with his excessive overfueling! :P
I ended up just de registering the car as it was sold anyway and paid the fine >_<
did u get fined by the cops or was it the epa. if the epa go over ur car u will find that i might be right
does any1 know where to get the already made 1s?. just jap was meant to be getting them over 6 weeks ago but doesnt look like there coming.
i cant send pms now for some reason. i write it out and push send and it doesnt com up in my sent items and never get replies back so id say they dont work. may just be this computer
improve gas flow
I mean to ask why does he need one... What makes him think it will help...
As an external venting wastegate pipe from a stock turbo will not seal properly from the main dump...
It will affect the back pressure on the turbine and hence cause it to take longer to spool. So infact it will not improve his situation...
Also its highlly illegal...
shuddup fool and let the man have his fun ;)
maximum of $10,000.
same as having a gutted cat.
emissions, flames, noise pollution...
ah crap. even before the engine build i had a no cat, flames & well over the legal db limit. I really wanted a screamer but i guess the amount of defects my car will have i really dont need the extra attention. I know sau doesnt support defective cars but i know i'm not alone on this situation
Import Auto Parts. i believe sells split dumps he might have have screamers available..dont know.
Yes IAP or Banzai Parts Garage or if all else fails ebays your good friend....or maybe look at classifieds on this website. They pop up quite a bit. Expect to pay around $250 plus!
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
