  • Replies 78
i agree stock turbos sound shithouse with a screamer pipe, a big external wastegate though venting to atmo sounds AWESOME but just in regards to the fines.. i recently went over the pits, no cat and screamer... nothing wrong.. and also my mate 04RNZ in an rx3... t66 high mount turbo, no intake pipe/filter, no mufflers, screamer pipe, went over the pits and was out as quick as he came in and nothin happened to him... i think nsw is a little tougher as i lived there, but still out of all the car enthusiasts i know, and deal through with work, i have never seen/heard a fine issued that big.... i do remember seeing a guy get done for excessive noise, but no EPA fines..also my bro inlaw just had his screamer pipe put on his rx7 and got pulled over, nothing came from that, and everything was fine...
ben...
Edited by 2BNVS
ok everyones bitchin about stuff, i know of two people who have had $9000+ dollar fines for screamer pipes they are a major defect which requires the vehicle to be returned to stock before it can be driven again....
Your mates got reamed then. How can they require you to return your car to stock because ONE thing doesn't comply. You are required to make the defecting thing comply with the law and that is ALL you don't have to rip off all your other legal mods just because you got done for one thing. If the two people you know did do as they were told they were very ill advised. The police cannot require you do remove modifications that are legaly applied simply as punishment for breaking a rediculous EPA law. I say it again atmo screamer pipes off large turbo's/wastegates not only sound tough, they give less restrictive flow....same goes for exhausts. Straight through is the only way!!!
+2
I swear so many people on here know someone who knows something who did something who received something, so many missed guided people
how can you tell if your cat is gutted? had the exhaust off when i changed the gearbox and it looked awfully empty... :P
Maybe just weld the cat heat sheild to the pipe so it looks like there's something there :(
Also screamer pipes & 2 flames FTW!
But turning a stock turbo to screamer is the gayest thing since brokeback mountain
1.) if this is for sound, just loosen one of your dump pipe bolts..
the gasket will burn out on that corner and you will hear the same stupid god awful screaching sound of an exhaust leak... this is exactly how a stock turbo, internal wastegate to atmo will sound.
2.) I work for QLD Police.... they can and will fine you the $10K...
As with any cop.. it depends on the individual cop who stops you. and your attitude at the time.
I train with a couple of them who were so annoyed with the individual driver with a bad attitude that they made an example of them..
Also, unless you have an engineers certificate for "ANY" modification from stock, you can be made to remove it.
so the guy above where his mates had to return to stock is very much possible.
de-reg and dodgey road worthy will be and has been found out before too.
that caused a larger fine than the so called mythical $10K fine..
make of this what you will.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
